Thread started 31 Jul 2013 (Wednesday) 15:39
Lightroom 5.2 Release Candidate is now available
Stone ­ 13
Jul 31, 2013 15:39 |  #1
http://labs.adobe.com/​downloads/lightroom5-2.html (external link)
preliminary Canon 70D support :)
new features:
  • A Smoothness adjustment slider has been added to the Detail Panel under Color Noise Reduction. This helps to reduce low-frequency color mottling artifacts
  • Refinements to the Spot Healing Tool:
    New Feather control
    Auto find source method now works better for images with textured areas like rocks, bark, and foliage
    Auto find source method now prefers source areas within the crop rectangle
  • Smart Preview size has been updated to 2560 pixels on the long edge.
  • Refinements to the Local Adjustment Brush:
    Right Click (PC) / Control-click (Mac) on a brush adjustment pin to bring up a context menu to duplicate or delete
    Control+Alt+Drag (PC) / Command+Option+Drag (Mac) on a brush adjustment pin to clone (duplicate) that adjustment
Issues list:
  • Catalog containing images processed with PV2003 were adding a post-crop vignette when catalog upgraded to Lightroom 5.
  • Pressing the “Reset” button while holding down the Shift key caused Lightroom to exit abruptly.
  • Output Sharpening and Noise Reduction were not applied to exported images that were resized to less than 1/3 of the original image size.
  • Incorrect photo was selected when trying to select a photo in segmented grid in Publish Services.
  • The Esc key did not exit the slideshow after right clicking screen with mouse during slideshow playing.
  • Import dialog remained blank for folders that contain PNG files with XMP sidecars.
  • Metadata panel displayed incorrect information after modifying published photo. Please note that this only occurred when metadata was changed after the photo was published.
Ken
Fujifilm X100T | 5D III gripped |35L | 24-70 2.8L II | 70-200 2.8L IS II | 85 1.8 | 430 EX II | Yongnuo YN-568EX | Billingham 445 | Think Tank UD 60 |
mclaren777
Joined May 2012
Jul 31, 2013 19:32 |  #2
Sounds great. I will probably buy it when 5.2 is finally released.
A simple comparison of sensor technology: Nikon vs. Canon (external link)
A technical comparison of sensor technology: Exposure Latitude (external link)
WesternGuy
Jul 31, 2013 19:45 |  #3
Thanks. What happened to 5.1?
Question answered - there is no 5.1! No, I don't know why.
WesternGuy
Bob_A
Gallery: 48 photos
Joined Jan 2005
Jul 31, 2013 19:48 |  #4
And here I was thinking LR 5.0 was a "release candidate" or maybe even a beta version. If the listed issues are really fixed then hopefully Adobe is now focusing on the sluggish performance of this product.
I typically wouldn't use an RC, but 5.0 is bad enough that I'm having trouble seeing how it can be anything but an improvement.
Bob
buggz
Jul 31, 2013 20:08 |  #5
I never upgraded from 4.
Looks like CS6 and LR4 is it for me.
No more Adobe purchases.
5DMkII, 40D w/ grip, lenses, flashes, more stuff.
Stone ­ 13
Jul 31, 2013 22:02 |  #6
Bob_A wrote in post #16171101 (external link)
I've been running it all afternoon and I can't say I see any measurable performance improvements in the RC.
Ken
tzalman
Fatal attraction.
Aug 01, 2013 00:30 |  #7
WesternGuy wrote in post #16171094 (external link)
WesternGuy
Probably the guys in the trenches had a version ready to go a couple weeks ago and the fat cats on the top floor told them it isn't good enough.
Elie / אלי
tzalman
Fatal attraction.
Aug 01, 2013 05:57 |  #8
O.K., I've had time to do a little comparing. The one bug in 5.0 that "bugged" me was the problem with images downsized for web posting - any image downsized to 1/3 or less than its original size did not get either output sharpening or NR. It wasn't a fatal bug because it could be set right with some extra work; sharpening and NR in a second or second and third application or, alternatively, reimporting the low res version back into LR 5.0 and exporting again at the same size. Still, it was a bug that needed fixing. So here are a couple comparisons; 5.0 on the left, 5.2 on the right, shot at ISO 6400. Both received identical editing including Luminance NR = 40 and exported with resizing to 450x667 pixels and Output Sharpening = High (100 ppi). Because the downsizing went a long way to hiding some of the noise in the original shot, the second illustration below is the same comparison at 3X so the difference in noise can be seen.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/08/1/LQ_657982.jpg
Image hosted by forum (657982) © tzalman [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/08/1/LQ_657983.jpg
Image hosted by forum (657983) © tzalman [SHARE LINK]
Elie / אלי
armis
Joined Jan 2012
Aug 01, 2013 07:24 |  #9
Why the color shift?
The smoothness slider sounds like it could help with some issues I've run into in the past. Wide-field astrophotography comes to mind.
Fuji X-T4, 18-55 and 55-200 zooms, Samyang 12
www.wtbphoto.com (external link)
tzalman
Fatal attraction.
Aug 01, 2013 09:25 |  #10
armis wrote in post #16172093 (external link)
Must be caused by the sharpening or NR, nothing else was different.
I don't understand that Smoothness. There is also (and has been since LR3) a Detail slider. I would have thought they are opposites. In the past I figured less detail means more smoothness, but now they both default to 50. Is Smoothness 50 in LR5.2 different than Detail 0 in LR4? When both are at 50 don't they cancel each other out? Clearly something that needs to be investigated, although, to tell the truth Color NR isn't something I think about a lot and mostly just leave it at its default 25 ecept for really high ISOs.
Elie / אלי
armis
Joined Jan 2012
Aug 01, 2013 10:08 |  #11
I don't know, I've always had Color NR at 50 or more by default as it didn't seem to hurt color rendition in any noticeable way, but helped heaps with noise. However, there were still fairly large but faint red and blue splotches (for instance here); I'm thinking that's what the new slider might be targeting? I dunno. To be honest I don't use my 5D2 much anymore and my X-E1 has like zero chroma noise SOOC anyway, so it's not something I expect to explore very seriously :).
Stone ­ 13
Aug 01, 2013 11:38 |  #12
from my experience, aggressive NR will sometimes introduce color shifts.
Ken
Stone ­ 13
Aug 01, 2013 11:43 |  #13
armis wrote in post #16172452 (external link)
That's what the new slider is supposed to be targeting, those random splotches of color left over after aggressive color NR. I can't say I have a lot of experience with it, most of the time I never touch color NR in LR.
Ken
Bob_A
Gallery: 48 photos
Joined Jan 2005
Aug 01, 2013 15:34 |  #14
Stone 13 wrote in post #16171370 (external link)
I would have expected that since there is no mention of performance improvements in the list. Hopefully (please Adobe) there are some once 5.2 is officially released in September.
Bob
monkeynuts1
Aug 01, 2013 15:39 as a reply to  @ Bob_A's post |  #15
Hmm have they stopped the hang-ups that 4 suffers with its doing my head in :(
7D and 1D mk3 24-105L.........70-200F2.8 L .............100-400 L lens and too much other crap
2,457 views & 0 likes for this thread, 8 members have posted to it.
1437 guests, 109 members online
