Thread started 04 Aug 2013 (Sunday) 08:48
So does a crop sensor also give more compression?
guitarjeff
Joined Feb 2012
Aug 04, 2013 08:48 |  #1
Hi guys. I am planning on selling my beautiful 5DII with only around 4000 shutter clicks because I want an articulating screen so I don't have to get on the ground so much, lol. This new 70D looks perfect and I should be able to basically sell my 5D2 for roughly the same price as the new body.
Also, I have a couple Sigma lenses i love, the 50mm Sigmalux and the 70 Macro, and I also like the idea of those lenses having more reach for portraits especially because I enjoy the compression with a longer focal length. But then it hit me, just because a camera is a crop sensor this won't make the pics more compressed as if using a longer focal length, will it? So if a face is a tad distorted because the focal length was too short for portraits, like with my 50mm Sigmalux, cropping it will do nothing to help the compression, correct? So when I use my 70 Macro for a portrait, I won't get the compression of a 100mm lens but just the reach and only because my pic is cropped in closer just as if I crop a pic in Lightroom made with my 5DII, correct?
If I am right that part sux, cause I will not get the benefit of more compression in the pic because of a longer focal length. But, the articulating screen is what I really want and I also require MA adjustment since I love my Sigma lenses so the new 70D is perfect for what I want.
John ­ from ­ PA
Joined May 2003
Aug 04, 2013 09:13 |  #2
No. Good expplanation at http://daryl-hunter.net …d-disseminated-confusion/ (external link).
You may might also take one of your lenses and a memory card to a store and try a 60D or T4i just to satisfy yourself.
sandpiper
Aug 04, 2013 09:38 as a reply to  @ John from PA's post |  #3
The compression is the perspective, and that does NOT alter because of focal length. You get the perspective because of where you stand, so stand in the same place and shoot with any lens and the perspective will be the same, you will get the same compression with the crop as with a FF. It won't alter between a wide angle and a telephoto either, yes the wide angle looks far less compressed but that is the angle of view, crop the centre of that image and match the telephotos framing and the perspective / compression will look identical.
That means that if you use a crop camera (same lens, same distance) you will get less of the subject in the shot, so to maintain your framing you will need to move further back and that will alter perspective and increase the compression you like.
auto-clicker
Aug 04, 2013 09:46 |  #4
No, focal length never changes only the FoV (Field of View) narrows when comparing FF to APS-C or smaller, that's why a 50 will "seem" like and 85 giving you that apparent "reach".
adas
Joined Aug 2004
Aug 04, 2013 09:56 |  #5
You can "mimic" any focal length by cropping, regardless of sensor size. But the sensor with the higher pixel density is always better to this.
6D, 20D, G7X
SkipD
Joined Dec 2002
Aug 04, 2013 10:16 |  #6
guitarjeff wrote in post #16179898 (external link)
You apparently believe that "compression" is caused by using a long focal length. As Sandpiper said above, this is a totally incorrect belief. "Compression" is simply perspective of a scene viewed from a longer distance and it is controlled by controlling the distances between the camera and the various elements in the scene.
Please read our "sticky" (found in the General Photography Talk forum) tutorial titled Perspective Control in Images - Focal Length or Distance?.
As to the change in camera format (size of the film frame or digital sensor): The smaller format camera (70D) will provide images that appear to have been made with a longer focal length as compared to the larger format camera (5DII) when both are used with the same focal length lens. The focal length of the is not actually changing when used on one or the other of the two cameras. The field (angle) of view is changing however, and that's purely a function of how much of the image projected by a given lens is recorded by the camera.
Since you may very well benefit from the following, I'm going to re-publish it here for you.
The "crop factor" is a reference number that relates to the difference in film or sensor size (known as the camera's "format") between two cameras like the Canon 7D and a 35mm film (or a so-called "full-frame" digital) camera. Let me list the facts:
35mm film cameras and so-called "full frame" DSLRs have a film frame or sensor size of approximately 24mm X 36mm, while the Canon 7D has an APS-C sized sensor, measuring approximately 14.9mm X 22.3mm. The whole line of Canon APS-C format cameras - starting with the D30 in the year 2000 and progressing through all of the "digital Rebel" xxxD series, the xxD series, and today's 7D - all have sensors that are approximately the same size (± 0.2mm).
When camera manufacturers started designing digital SLRs (DSLRs), they decided that the DSLR bodies should be about the same physical size and configuration as their 35mm film SLRs. For that reason, they concluded that they could use the line of lenses they already had for their 35mm SLRs on the new DSLRs.
All lenses designed for 35mm film cameras project an image circle onto the film that covers a 24mm X 36mm rectangle. The 35mm camera records the portion of that image circle that is defined by the opening behind the shutter for the film (24mm X 36mm in size). A digital SLR with an APS-C sized sensor only records the smaller area (approximately 14.9mm X 22.3mm) of the image circle projected by the same lens.
When you put a 100mm lens on a 35mm film camera and make a photograph, then put the same lens on a DSLR such as the Canon 7D and make a similar photograph - same subject, same position for the camera, and same focal length - and then enlarge both photographs to the same size print (4 X 6 inches, for example), it will appear as though the photo from the Canon 7D was taken with a longer lens. That is because the image recorded by the Canon 7D was of a SMALLER PORTION of the image circle projected by the lens - cropped, if you will - compared to the image recorded by the 35mm camera.
The special lenses made by Canon for the 7D (and other Canon APS-C cameras starting with the 300D - the first Digital Rebel) are called the EF-S series. These project a smaller image circle, making the lenses less expensive to design and produce in wide-angle and extreme wide-angle formats. The EF-S lenses also project deeper into the camera than the EF specification allows (the "S" referring to "Short back focus), allowing for less expensive wide-angle lens designs. However, an EF-S lens set to 40mm will produce the exact same image as an EF lens set to 40mm if both lenses are used on the same APS-C format body and both lenses are focused at "infinity". Focal length is focal length, period. In addition, all lenses designed for SLR cameras (and most other "real" cameras) are marked with their actual focal length. No lenses for SLRs are marked with a "35mm Equivalent Focal Length" value, though you may find this on some point-n-shoot camera lenses.
Now to the primary point that I want to make: NOTHING about lens EVER CHANGES when you put it on different format cameras. Focal length never changes. Aperture range never changes. The only thing that would change is the apparent field of view, and that change is not a function of the lens but it is a function of the size of the sensor or film that will record the image.
The "crop factor" is NOTHING MORE than a REFERENCE between two camera formats that lets you compare the field of view of particular focal lengths between the two formats. For the photographer who started with an APS-C format DSLR and has never used a 35mm format camera (at least enough to have developed a feel for what certain focal lengths provide him/her), the "crop factor" calculations can be completely forgotten for day-to-day lens selections. Only when comparing two camera formats is the "crop factor" useful.
The "crop factor" calculation for "35mm equivalent focal length" has only one valid use. That is for comparing the field of view of lenses used on two different format cameras.
Here's one common example: Joe took a photo of Mount Rushmore with a 35mm camera from a particular place using a 200mm lens. You want to replicate that photo with your Canon 7D. What focal length do you need to do that from the same location that he took his photo? Divide the 200mm by 1.6 and you get the answer - 125mm.
Here's another popular example: Mary Sue has been using a Canon SX120 IS point-n-shoot camera and is wanting to use a Canon 50D DSLR. She is, of course, interested in what focal lengths she would need to keep the versatility of the SX120 camera's 10X super-zoom lens. The SX120 lens is actually a 6.0mm to 60.0mm lens, but the advertising also shows the "35mm equivalent" focal length range as 36mm to 360mm. To know the focal lengths needed for the 50D, merely divide the "35mm equivalent" values by 1.6. In other words, Mary Sue would need 22.5mm on the short end and 225mm on the long end for the 50D to have the same field (angle) of view coverage as her SX120 IS camera.
The "crop factor" (as related to using lenses essentially designed for 35mm SLR cameras) is always given assuming that the 35mm film format (24mm X 36mm) is the reference master. Something to realize, though, is that the 35mm film format is not, never has been, and never will be the "master" format against which all other camera formats are referenced. It is simply the format of the cameras that have also evolved into today's commonly used digital SLRs.
Beginning photographers are often first confronted with the crop factor puzzle when choosing their first DSLR camera. Intuitively, "Full Frame" sounds better than "Cropped", as if one is getting a complete camera instead of a partial camera. There are very few really significant differences (other than features) between similar-generation cameras of different formats. The fact is that both format cameras can be used to make essentially identical images, though different focal lengths will be needed on them to keep the framing the same.
Beginning photographers are also confronted with "crop factor" issues when buying lenses. Focal length (translated to how big or small of a field of view you want) is the first factor to consider when asking the “which lens?” question. The beginner doesn't have to convert every focal length to its "35mm equivalent focal length" value but they should know that, on their APS-C camera, a 28mm lens isn't going to be wide angle but instead is a "normal" focal length and that a 250mm lens is going to be a rather long telephoto.
Many photographers who are new to DSLRs have acquired some very wrong ideas about "crop factor" issues. For example, they sometimes expect the focal lengths of EF-S lenses to be different (as in the focal lengths being pre-converted for the "crop factor") than the focal lengths of EF lens. This is completely false, as all SLR lenses are marked with their actual focal lengths. In addition, many new photographers who use APS-C format DSLRs seem to have been fed with the idea that they need to employ the "crop factor" calculations whenever thinking about using lenses on their cameras. This is generally not necessary at all as I have outlined above.
The answer to your thread title is definitely "no" and, hopefully, you now understand why that is the correct answer.
Skip Douglas
3,416 views & 2 likes for this thread, 6 members have posted to it.
1463 guests, 131 members online
