Thread started 06 Aug 2013 (Tuesday) 22:56
Step Down Ring
effstop
Aug 06, 2013 22:56 |  #1
I have a lens with a 77mm thread diameter but have a 72mm Heliopan filter that I'd like to use. If I get a 77mm-->72mm step down ring will I run into any image issues? Vignetting, shadows, or anything of that nature? Thanks!
5D MKI | 1D MKII | 24-70mm 2.8 L | 80-200MM 2.8 L | 400mm 5.6 L |50mm 1.8
afoton
Joined Apr 2012
Aug 07, 2013 02:02 |  #2
Maybe. It depends on what lens you are using. Some lenses have bigger filter diameters than necessary, then it will works with a step down.
For tele lenses it is pretty easy. If the entrance pupill is bigger than 72mm, you will run into some trouble. But most likely you can fix it with just stopping down.
For wide angle, stopping down will not allways fix this type og vignetting, mayby it will just sharpen the vignetting edge. But maybe you can find it usable with just some croping.
Anyway, a step down ring is not that expensive. Go get the ring, and try for your self with your own lens.
ralff
Aug 07, 2013 04:48 |  #3
You will have problems, buy a larger filter. Never use a ring to step DOWN, always step UP.
Canon 6D - Canon 7D - gripped, Canon 50D - gripped, EFS10-22mm, 17-40 f4 L, nifty-fifty, EF 28-135mm IS, 100-400 f4.5-5.6 L IS USM, Tokina AT-X 100mm f/2.8 ProD Macro, Benbo Trekker, Feisol 3371 w/ Kirk BH-3 ball head - Epson Pic-Mate, Epson 2200, Epson 3880 :D http://www.flickr.com/​photos/WNC_Ralph (external link)
archer1960
Gallery: 6 photos
Aug 07, 2013 07:15 |  #4
ralff wrote in post #16187706 (external link)
Not necessarily; it depends on the lens. Some will vignette in this situation, others won't.
Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
effstop
Aug 07, 2013 07:38 |  #5
The lens is a Canon 24-70mm.
archer1960
Gallery: 6 photos
Aug 07, 2013 11:07 |  #6
effstop wrote in post #16187918 (external link)
Is your 1DII 1.3 crop, or full frame (I don't remember). If it's the crop, you'll probably be fine. FF might vignette a bit, especially at the wide end.
BufordFZ1
Joined Oct 2011
Aug 07, 2013 11:39 as a reply to  @ archer1960's post |  #7
Try Adorama.
They have several step up and step down ring sizes available.
A2, 60D, 5DII
Canon EF 17-40mm L
EF 100mm L
Canon EF 70-200mm f/2.8L
Canon EF 400mm f/5.6L USM,Canon 50 1.4, 430 EXII,580 EXII
bratkinson
Joined Dec 2011
Aug 08, 2013 06:52 |  #8
When buying step up/step down rings, be VERY CAREFUL reading the description before you click 'add to cart'. Look specifically for wording like 'use smaller filter on larger diameter screw ring' or something like that.
Depending on the manufacturer (I think), some use the term 'step down' to reference a smaller filter in a bigger screw in ring, and others use 'step down' to mean a too-large filter to a smaller size lens screw ring. I have several 'step down' sizes to put 82mm filters on lenses with 67, 72 and 77mm filter size threads and almost bought the wrong 'direction' rings.
Again, read the description carefully, and, if possible, enlarge the picture(s) to make sure it has the threads where they should be!
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." General George S Patton, Jr 1885-1945
effstop
Aug 09, 2013 18:42 |  #9
So, the 1D MKII is a 1.3 crop so I shouldn't run into any vignetting right?
1,912 views & 0 likes for this thread, 6 members have posted to it.
Step Down Ring
Latest registered member is EBiffany
1605 guests, 98 members online
