Hi All,
Playing with my 650D and an older 420EX flash. I've got it to successfully use the in-built flash on the camera to wirelessly trigger the 420EX, which is great.
Couple of questions, though -
* Does using a 420EX wirelessly still give E-TTL when triggered by the on camera flash?
* As the 420EX does not have manual controls on the back of the flash, can I use the in-camera flash compensation via the menu and have it still work wirelessly to control the 420EX output, or does this need a wired sync cord to do?
* If I'm using the 420EX ON camera, then presumably the flash exposure compensation in the camera menu will work normally?
I'm working up to some club photography so need a method of balancing available light with flash...
Any tips much appreciated.
Ric
