mrdunu wrote in post #16206064
Thank you for the extensive replies!
To answer a few of your questions:
a) I have already pulled the trigger on the Ranger RX Speed. My reasoning is so that I can shoot during the day (and use the sun as a rim light), along with the occasional sunset shots
b) I will primarily be working solo, however I can possibly arrange to have an assistant with me
c) It seems as though a large shoot through umbrella is a popular choice. I've seen other photographers using a beauty dish over a shoot through umbrella when it comes to pre-wedding shoots, hence my reasoning for wanting one. Yes I know I should do my own research, but I figure the Mola Setti *should* give me the look I'm after. Though when it comes to preference, what do you guys prefer? The look of a large shoot through umbrella? or a 28 inch beauty dish?
and @dmward, the second shot looks amazing! I'm not a fan of the first, but that's just personal preference!
I always prefer umbrellas because they're CHEAP, portable, and quick to set up. Like I said, the only problem is the wind. I've had an assistant hold a tripod down with an umbrella on it so it wouldn't fly away... what happened was the umbrella completely flipped inside out and all the metal pats bent and broke.
One thing to remember with shoot thru vs bounce umbrella, the shoot thru causes light to go through the umbrella to the subject, AND also reflects some light back... sometimes even into your lens, which is a problem. A shoot thru umbrella with a black backing will prevent that. A shoot thru umbrella is also better IMO because you can place the umbrella as close as you want to the subject, literally 1" away from the face if you wish. At that close distance, a large umbrella is huuuuge compared to the subject, so lighting becomes REALLY SOFT. Shoot thru umbrellas without black backing have a lot of light spilling everywhere, which is its downfall.
with a bounce umbrella, the closest you can get the umbrella to the subject is several feet, since the light + length of umbrella shaft is closest to the subject, not the umbrella.
