OK, I've purchased LR5 in the believe that I can use it to get more out of my photos, and since I knew it was arriving sooner than later I downloaded the trial version from Adobe (after a bit of run-around on the website). Probably could have done that a while ago, but I was lazy.
Here is a photo I edited in LR5. It's a bit of a mundane subject, but I'm fairly happy with the result of an evening shot experimenting with high-ISO and ETTR (T3i, 17-55 @ 28mm, f/2.8, Av mode with +1/3 exp resulting in 1/15 sec, ISO 3200), exported as jpg:
Here is the same Canon raw file (.CR2) edited in DPP 3.13.10, tweaked and exported as jpg of course:
I have tried my best to re-create the final image I got out of LR5, but for the life of me, I cannot. I'm not complaining - I think the LR5 result is better, but it bugs me that I can't repeat the overall contrast and detail of the image in DPP - not even close.
Specifically, look at the light in the fountain water to the left "behind" the fountain base: the amount of detail far exceeds what I could eke out of DPP. Or the white square shelving units in the store that has the burgundy awning: the LR5 version has a lot more detail.
I used the fountain itself as a guide for matching results, as well as the store fronts across the street in the background.
I realize the better color rendition of the LR5 output is from the more advanced vibrance and saturation, and the better surface contrasts from the clarity controls. But I cannot wrap my head around why DPP isn't able to get the overall detail (via contrast adjustments) that LR5 seems to automatically find.
Is this typical? Again, I'm not complaining, just curious, and happy that I may be procuring a tool that is apparently going to give me better results. Maybe the tools are equivalent, but I'm just able to get what I want more naturally in LR5.
Comments welcome.
shinksma
