I've tried both the on-board graphics with my i7-4770 set-up and a Radeon HD7770 card, but I cannot get color management to work at all for my Windows 8 computer.
I have a NEC PA241W monitor that I hardware calibrate with NEC's SectraView II. It works perfectly on my Win 7 (i7-930) machine ... after connecting the puck and installing the software you run the calibration and get perfect results every time. I don't touch ANYTHING in Windows Color Management. Couldn't be simpler.
However, here are the bizarre things I'm seeing with Win 8:
1. I calibrate to full gamut and have an aRGB image as my Windows desktop. After calibration the image looks too bright and over-saturated. I check how it's tagged in Bridge, and sure enough it's aRGB. Weird.
2. I open up bridge and click on the folder with an sRGB and aRGB version of the same image. The preview looks identical for both versions ... and the preview has the proper saturation and brightness.
3. I minimize bridge and then maximize it and the preview of the selected image is overly saturated and bright, matching the desktop.
4. I click on the other version of the image in Bridge and the thumbnails and previews instantly correct to the proper brightness and saturation.
It seems like somehow Win 8 has a standard monitor profile that is conflicting with the profile created by hardware calibration. Since I can calibrate to a different luminance and actually see the Windows desktop image adjust (although both instances the image is rendered wrong) it's almost like there is some sort of double profiling going on.
I thought at first that it was the new Intel on-board graphics, so I took the Radeon HD7770 card out of my other PC where calibration works perfectly, installed it with the latest drivers for Win 8 ... and got exactly the same result.
The good thing is that minimizing or maximizing in LR or PS CS6 doesn't change the image preview.
Anyone have any ideas?
