Trying a different editing technique to a set I posted previously. C&C welcome
_MG_0357_DxO
tmoore323 Goldmember 1,945 posts Likes: 4 Joined Oct 2010 More info | Aug 17, 2013 01:49 | #1 Trying a different editing technique to a set I posted previously. C&C welcome _MG_0357_DxO
JeremyKPhoto Goldmember 1,634 posts Likes: 46 Joined Apr 2012 More info | Aug 17, 2013 01:53 | #2 The light is really harsh and looks way to over-sharpened to me. 5D Mark III / 70-200 2.8L IS II / 24-105L / 50 1.8 stm / Tamron 70-300 VC / Sigma 85mm 1.4 Art
Aug 17, 2013 10:38 | #3 Ratjack wrote in post #16215182 The light is really harsh and looks way to over-sharpened to me. He's very pale, and she's very tanned/dark so is that what makes you think that?
Aug 17, 2013 11:16 | #4 Harsh meaning direct (on camera). Also looks a bit cool or blue in the temp department. Dave
Aug 17, 2013 11:21 | #5 ChunkyDA wrote in post #16215974 Harsh meaning direct (on camera). Also looks a bit cool or blue in the temp department. Why are they wedged in the left side? This was with an external flash, TTL, on top of the camera with a diy Gary Fong type diffuser. One of my first times using it (TTL Flash), always manual external flash before... _MG_0357_DxO-2
thcomb Member 55 posts Joined Jun 2013 Location: Wichita, KS More info | Aug 17, 2013 23:05 | #6 This isn't huge, but the tree growing out of the top of his head is distracting to me. I would have reframed in the green part behind the girl.
navydoc Cream of the Crop More info | Your first edit appears overexposed and the second appears a little under exposed on my monitor. I agree that the tree behind the boy is distracting too. Image hosted by forum (659636) © navydoc [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Gene - My Photo Gallery ||
Fire0725 Member 222 posts Likes: 1 Joined May 2011 More info | Aug 18, 2013 07:19 | #8 I love the pose, and the composition is great! But... (sorry there, is always a but, eh?)... the lighting is awful. I'm wondering if you might consider turning it into a B*W to see if that solves the lighting issues at all? Just a thought. Canon 7D
Aug 18, 2013 09:19 | #9 What does the DIY diffuser look like? The flash is still mounted on the same axis as the lens and a few inches away, therefore it is direct lighting. See the harsh shadow of chin on neck? The Gary fong stuff I have seen is used indoors where there is walls and ceiling to try and get some bounced light. Outside this is nearly useless but it does make a 3 square inch source into maybe 9 square inch and rob your light of much of its power by directing it into the air and not your subject. Dave
Aug 18, 2013 10:53 | #10 I think NavyDoc's edit and crop is spot on but I'd clone out the little blue antenna sprouting from his head. -- Image Editing OK --
Aug 18, 2013 13:27 | #11 ChunkyDA wrote in post #16218155 What does the DIY diffuser look like? The flash is still mounted on the same axis as the lens and a few inches away, therefore it is direct lighting. See the harsh shadow of chin on neck? The Gary fong stuff I have seen is used indoors where there is walls and ceiling to try and get some bounced light. Outside this is nearly useless but it does make a 3 square inch source into maybe 9 square inch and rob your light of much of its power by directing it into the air and not your subject. Here is a link to the DIY instructions, and I agree this thing works great indoors:
Aug 18, 2013 13:28 | #12 Qbx wrote in post #16218386 I think NavyDoc's edit and crop is spot on but I'd clone out the little blue antenna sprouting from his head.
Aug 18, 2013 13:37 | #13 and hrm, guess I need to re-calibrate my monitor more often, or maybe before every edit...
Aug 18, 2013 13:52 | #14 Now that I'm re-calibrated I took Navy's edit without any changes (except to get rid of QBX's antenna)
navydoc Cream of the Crop More info | Aug 18, 2013 13:55 | #15 Qbx wrote: I think NavyDoc's edit and crop is spot on... Thanks. Qbx wrote in post #16218386 ...but I'd clone out the little blue antenna sprouting from his head. Boy, see one black dot on a large white sheet... Gene - My Photo Gallery ||
| Latest registered member is semonsters 1085 guests, 116 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
