Thread started 17 Aug 2013 (Saturday) 11:05
canon fisheye vs sigma fisheye
Nick ­ Aufiero
Gallery: 6 photos
Joined May 2013
Aug 17, 2013 11:05 |  #1
Being used on Canon 6D
Need for Skateboarding and indoor concert shooting( mainly right on single person, but as full band on stage as well)
I want good quality but at the same time, its skateboarding and hardcore music, quality isn't the biggest thing.
I want a good fisheye around 12mm but haven't seen any well regarded for fullframe.
Anyone have any thoughts?
Main concern is brand new sigma is $610 USD and new canon is around $750 USD.
Opinions or help are much appreciated.
Nick ­ Aufiero
Gallery: 6 photos
Joined May 2013
Aug 17, 2013 11:32 |  #2
1Also, any lens between 10-22mm would be fine, since its on a full frame.
also considering the 17-40mm L lens
since its 740 online new
Madweasel
Aug 17, 2013 17:26 |  #3
Your second post makes me wonder if you're clear on the difference between fisheye lenses and non-fisheye (referred to as rectilinear) lenses. Fisheye lenses take in an enormously wide field of view - normally 180 degrees or so. They can only do this by allowing straight lines in the scene that do not pass through the centre of the image to curve. They use a particular kind of image projection that marks the image out as different from normal, rectilinear ultrawides like the 17-40L.
On your 6D you really only have three currently-made options for a rectangular-frame fisheye: Sigma and Canon 15mm lenses (actually even the Canon is now discontinued, but there are still some around), which are roughly equal in quality - both good, and the newer Canon 8-15L fisheye zoom, which is extemely good, but expensive. The Tokina 10-17mm fisheye will give a rectangular field on full frame at about 15mm, but it's really designed for crop cameras. I just remembered the cheap manual option of the Zenitar 16mm. It's not bad at all for the money, but aperture and focus are all manual.
Other fisheyes with shorter focal lengths are either made for crop cameras, or are designed to give a circular image on full frame.
Mark.
986 views & 0 likes for this thread, 2 members have posted to it.
1361 guests, 109 members online
