Samsen,
First I use this software which will create 3 files if there is a transit found: A text file, and two Google Earth files. Warning: It's not exactly the most user friendly software in the world.
http://pictures.ed-morana.com/ISSTransits/predictions/
Here are the three files that was generated for this particular pass:
http://doublea.speedgeeks.org/iss-transit/predict.txt
http://doublea.speedgeeks.org/iss-transit/predict.goo
http://doublea.speedgeeks.org/iss-transit/predict.kml
Then I looked around Google Earth for a suitable place to sit for an hour or so. In this case I figured a hardware store parking lot off of KY 224 in Upton, KY would be the best based on the weather report and less of a chance of people bothering me. I then called the store and got permission to shoot on their property.
Then I took the coordinates of the hardware store, and plugged it into Heavens Above to get more info on the pass. I always click on "All Passes". If you click through and find the exact pass, it will show you where the ISS in the sky at what time.
http://www.heavens-above.com/
Here is the star chart of this pass at the location of the hardware store:
http://doublea.speedgeeks.org …rdware_store_upton_ky.pdf
In this chart, you can see that the ISS will transit the moon between 23:17 and 23:18. This is great if you can see the ISS, but this wasn't a visible pass. It required more work.
To find the exact time, I then took the coordinates of the store 37.465088, -85.910248 and looked at the predict.txt file to find the closest location and find the time.
44.8 NE 18 Aug 231746 36.2 -173.9 419 37.4678 -85.9058 224 2.7 n -35.7 153.3
In this case, the only thing I cared about was the 231746, which was 23:17:46. The exact time of the transit at that exact location.
Now comes the easy part. Shooting in Manual, I set an exposure for the moon starting with 1/1000s shutter speed (I should have done 1/1600s as the solar panels aren't as sharp as I have gotten previously and I think that extra 2/3stop would have gotten it.). In this case I used 1/1000s, F/10, ISO 400. Then set the camera at hi-speed continuous, Manual focus, OS/IS off.
Two minutes before the pass, I made sure the moon was in frame, (because it moves fast at 700mm on a crop). Using an app on my phone with time synced to 5 NTP servers, I just waited for the time. Then I just held the remove shutter release down a few seconds before 23:17:46 and hoped I got it before the buffer filled. I normally shoot RAW, but shot JPG this night. With the 7D I had 15s of buffer with JPG, and only 3.5s with RAW.
That's it. I'm sure there are better ways of doing it and I welcome any advice or suggestions.
Hope this helps,
Aaron
