Thread started 19 Aug 2013 (Monday) 16:55
MacBook Air with an External Monitor as Sole Computer?
battleborn_nevada
Joined Oct 2012
Aug 19, 2013 16:55 |  #1
I am looking at ordering a new Mac, and looking at a 13" MacBook Air i7 with 8GB of RAM. I was wondering if the group thought I could get away with using this as my only computer with an external monitor when I am home, and a bevy of USB Hard Drives. I would be running CS6, LR5, and Nik Plug ins...
Reno, Nevada
Canon 6D | Web (external link) | Flickr Gallery (external link)
Bob_A
Gallery: 48 photos
Joined Jan 2005
Aug 19, 2013 23:36 |  #2
Depends on what you expect for performance. For me a totally tricked out MB Air is hugely underpowered for CS6 and LR5, however it would probably be OK for CS5 and LR3.
If I were looking for a MB for photo editing using CS6 and LR5 (both are resource pigs), and was using an external monitor, I would be going for a MB Pro 13", 2.9GHz with a 256GB SSD as an absolute minimum spec, but would prefer the 16GB RAM I could get with a 15" model.
IMO for seamless operation of LR5 and CS6, with no laggy brushes, etc. you need a desktop with 4.0 to 4.2GHz processor, fast SSD for your OS, catalog and previews, multiple hard drives for scratch disks and 16+GB RAM. If you use that end of the scale as excellent (A+) and the MB Air as close to the bottom end of the scale (D-) you can decide how much you want to compromise performance for portability. Everybody's needs and expectations are different, so honestly as long as you make an informed decision and know what to expect there isn't a wrong answer ... after all, a desktop scores an F for portability :).
Bob
Colorblinded
Gallery: 18 photos
Aug 19, 2013 23:53 |  #3
It wouldn't be my first choice, then again no laptop really is.
Bob_A covered it all. As far as I'm concerned if you want a smooth and responsive experience you need a desktop. More performance for your dollar anyway. It's really about what you need and what you expect from it.
http://www.colorblinde​dphoto.com (external link)
http://www.thecolorbli​ndphotographer.com (external link)
battleborn_nevada
Joined Oct 2012
Aug 20, 2013 00:02 as a reply to  @ Colorblinded's post |  #4
Sounds like I should pick up the 13" MacBook Pro 2.9GHz and upgrade the RAM to 16GB.
Reno, Nevada
Bob_A
Gallery: 48 photos
Joined Jan 2005
Aug 20, 2013 01:08 |  #5
battleborn_nevada wrote in post #16223257 (external link)
Not sure that you can get 16GB with the 13" version. If you can then it would be a decent choice.
Bob
Colorblinded
Gallery: 18 photos
Aug 20, 2013 09:06 |  #6
If you can that sounds pretty solid. For me 8GB was just edging out not being enough a good majority of the time, and there were certainly times with my old system where it got in the way.
Tony-S
Aug 20, 2013 10:01 |  #7
battleborn_nevada wrote in post #16222322 (external link)
I have this MacBook Air and its performance is really tied to the software you're using. For Adobe's apps, which are cpu-tied for nearly all meaningful functions and are memory hogs, the i7 MBA 8 is a very good computer. However, if you use Aperture, Pixelmator and the Nik Suite, which heavily rely on the gpu, it is a superb processing system. It renders my 5D Mark II files in real-time and is plenty fast for moderate use. If you're doing weddings or some other photography that requires lots of batch exporting, then quad-core or more would be better. But for virtually anything else the 2013 MBA i7 is an excellent computer. It is faster than my 2010 dual-core i7 MacBook Pro with its dedicated ATI graphics card. The HD5000 gpu in the current MBA is a very nice improvement on the HD4000, the first Intel gpu that could render my 5Dii files in real-time. And the ePCI SSD is quite a bit faster than SATA SSDs.
In terms of expandability, if you buy the Apple 27" Thunderbolt display you will also get a FW800 port if you want to use that for daisy chaining external hard drives. Of course, for better performance, you can buy a USB3 hub that connects to the MBA's USB3 ports (the Thunderbolt Display only has three USB2 ports). The Apple display also gives you gigabit ethernet for your MBA as well as an additional Thunderbolt port for a second display, hard drive/SSD, or other peripherals.
I almost never take my MBP with me when I travel because the new MBA is quite a workhorse, and the weight and battery life make a huge difference for me.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
Tony-S
Aug 20, 2013 10:08 |  #8
Bob_A wrote in post #16223345 (external link)
The non-Retina MacBook Pros can be upgraded to 16 GB, although Apple only offers 8 GB options. In addition, one can remove the DVD drive from the MBP and install a second drive. The advantage of this is you can put in a 1.5 TB hard drive and an SSD (9.5mm) of any size available, then initialize the two drives as a single Fusion volume for maximum performance.
battleborn_nevada
Joined Oct 2012
Aug 20, 2013 11:08 |  #9
Tony-S wrote in post #16224182 (external link)
Does your MBA stumble with the Nik Collection?
Reno, Nevada
jptsr1
Aug 20, 2013 11:12 |  #10
My setup is a MPB 2.9GHz dual-core Intel Core i7 with an external monitor and it struggles with Lightroom and with large batches in DPP. Gets along fine for my uses but I know for sure when its at its limit.
Edit: mine only has 8gigs of ram.
Et Facta Est Lux
Flickrexternal link
Tony-S
Aug 20, 2013 11:45 |  #11
battleborn_nevada wrote in post #16224394 (external link)
Not at all. Now that Nik's Silver Efex Pro, Color Efex Pro and (I think) Viveza use the gpu, the performance is very nice.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Aug 20, 2013 23:51 |  #12
Tony-S wrote in post #16224507 (external link)
As I said, it all depends on the user and his/her expectations. A MBA would drive me nuts where I could live with a 13" MB Pro with a 2.9GHz processor and 16GB RAM if I absolutely needed to have portability.
Bob
battleborn_nevada
Joined Oct 2012
Aug 22, 2013 14:47 as a reply to  @ Bob_A's post |  #13
So it looks like I can get a 13" MacBook Pro 2.9 i7 with 16GB for $1249, a 13" retina MacBook Pro i5 with 8GB RAM for $1499, or a non retina 15" MBP 2.3 i7 quad with 16GB RAM for $1599.99...
I think I can swing any of those three, just wondering if the 15" is worth the extra cash for Lightroom and CS6 work.
Reno, Nevada
Tony-S
Aug 22, 2013 19:07 |  #14
If you're planning to use an external display, I wouldn't get a Retina because you cannot upgrade them. The non-Retinas can be upgraded to 16 gb of RAM and you can replace the DVD with a second drive, HD or SSD, including making it a Fusion drive.
battleborn_nevada
Joined Oct 2012
Aug 23, 2013 10:57 as a reply to  @ Tony-S's post |  #15
Funny how this process worked out....I came here seeking advice on a MacBook Air and yesterday picked up a 15" MacBook Pro...
Reno, Nevada
4,353 views & 0 likes for this thread, 5 members have posted to it.
926 guests, 117 members online
