I have bought the 50mm 1.2 and so far, I love it.
One thing i hardly noticed and that i never thought it would make so much difference is:
This lens is VERY soft – if you dont know how to use it. Even if you focused and you only moved a little bit back or forth the subject will most likely be OOF at 1.2. I was wondering why some shots are incredibly sharp while others are not, until i noticed this.
Never thought that makes so much difference but now, I press the shutter with that lens while focussing. That way it shots right after AF is set properly. Also i try to minimize handshake to avoid these limitations!
