Thread started 19 Aug 2013 (Monday) 20:04
Orion StarBlast Auto Tracker
the ­ jimmy
Aug 19, 2013 20:04 |  #1
Stumbled across this today, can tack for astrophotography, viewing, also controls Canon cameras for panoramic and time lapse photography. Seems to be a lot for a little ($199 US), still would like to read a third party review. Website LINK (external link)
SteveInNZ
Aug 19, 2013 22:03 |  #2
It really needs a wedge for astrophotography. But good value for the other applications.
"Treat every photon with respect" - David Malin.
gmikol
Aug 20, 2013 12:23 |  #3
SteveInNZ wrote in post #16223047 (external link)
Does it? My reading of the manual is that this is like a dumb "Go-To" mount. It's motorized in both axes. So after you've set it up, with regards to latitude and north, it adjusts its movement rate based on where it's pointed.
Maybe I'm misunderstanding...I'm by no means an expert in these fields. But if it's not not capable of tracking for astrophotography, it's not capable of tracking for optical observing, either. And that's not what the manual says.
Can you expand on your concerns regarding the suitability of this mount?
Thanks--
Greg
SteveInNZ
Aug 20, 2013 15:20 |  #4
If you track with an Alt-Az mount, the field appears to rotate. That's not a problem for visual observing because you're only interested in the thing in the middle and not for very long. With photography, you'll get star trails centered on the middle of the field, rather than on the celestial pole as it would if it was on a fixed mount. The amount of field rotation depends on where in the sky you are pointing.
If you put an Alt-Az mount on a wedge, the Az axis rotates around the celestial pole, making it equatorial and therefore, no more field rotation.
gmikol
Aug 20, 2013 16:18 |  #5
Thanks for that...I came across another reference to that at about the same time you were writing your response, and it was a forehead-slapper.
Of course that's why...why didn't I think of that!!!???
--Greg
the ­ jimmy
Aug 20, 2013 16:41 |  #6
SteveInNZ wrote in post #16225153 (external link)
If you track with an Alt-Az mount, the field appears to rotate. If you put an Alt-Az mount on a wedge, the Az axis rotates around the celestial pole, making it equatorial and therefore, no more field rotation.
So to make this work for astrophotography a person would need to build a wedge that can be set at the local latitude. Correct?
SteveInNZ
Aug 20, 2013 17:37 |  #7
the jimmy wrote in post #16225393 (external link)
The simple answer is yes. If you put it on a wedge the limiting factor would be your polar alignment and the time limit would be the same anywhere in the sky. If you tracked in the standard Alt-Az configuration you could do 5 seconds directly overhead or a couple of minutes towards the east or west horizon (based on a limit of 0.1 deg of rotation from Covington's book).
trevorklat
Joined Mar 2012
Aug 21, 2013 12:54 as a reply to  @ SteveInNZ's post |  #8
Given that the base has a 1/4"-20 female screw mount, can someone recomend a manufacturer's adjustable wedge that I could use between the StarBlast mount and my tripod?
3,943 views & 0 likes for this thread, 4 members have posted to it.
1522 guests, 131 members online
