Thread started 20 Aug 2013 (Tuesday) 22:30
General C&C Please - Experimental
KirkS518
Joined Apr 2012
Aug 20, 2013 22:30 |  #1
I'm looking for general feedback on these. They were quick experimental test shots I took this afternoon using a very odd lens. PP was only LR5 'Auto', some boost in vibrance/clarity, and some noise reduction. No sharpening or blur applied. Just want to see if these have an appeal to them.
IMAGE: http://i486.photobucket.com/albums/rr224/Beefer518/Camera%20stuff/exp/IMG_8611_zpsdeb40346.jpg
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/08/3/LQ_659930.jpg
Image hosted by forum (659930) © KirkS518 [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/08/3/LQ_659931.jpg
Image hosted by forum (659931) © KirkS518 [SHARE LINK]
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
stanclark
Joined Jan 2012
Aug 21, 2013 01:32 |  #2
as they are...just okay, but I think you could make an abstract painting in post......
So if God made Man & Woman....whats his excuse for Nikon...
PipesInTune
Aug 21, 2013 11:16 |  #3
I think they're too soft. When you start to see halos around the subject (in this case the flowers) I think you've gone too far. Take some test shots with varying degrees of softness and see which one looks best. Kind of like with portraits...you can make it too soft and it loses detail, too sharp and you see more detail than you'd like. I don't think you can go wrong with sharper flowers...it's the detail that makes them interesting.
KirkS518
Joined Apr 2012
Aug 21, 2013 11:35 |  #4
That's the thing - I didn't create the softness, nor did any post work, it's created by the lens. These were taken with an x-ray lens, Rodenstock 95mm f1/6.
Naraly
Joined Feb 2012
Aug 21, 2013 16:17 |  #5
bannedPermanently
I like the last two. I think this is different and intriguing, maybe something that could be put on the wall in an artsy place. Maybe I'm just saying this because I put a lot of painting on my walls and it reminds me of that :p. I think that's neat that it wasn't done in post, as soon as I saw them I imagined they were over processed.
KirkS518
Joined Apr 2012
Aug 21, 2013 18:46 |  #6
Thanks Naraly. #3 is my favorite, with #2 as runner up. Getting a print of #3, and it's going on the wall (I think).
chubbyone
Joined Mar 2013
Aug 21, 2013 22:39 |  #7
They don't appeal to me. Just chiming in.
I like the composition of #2, but would prefer the flowers sharp with creamy background.
6D | EF 35 f2 IS | EF 50 f1.4 | EF 85 f1.8 | EF 135 f2.0
KirkS518
Joined Apr 2012
Aug 21, 2013 23:15 |  #8
chubbyone wrote in post #16229137 (external link)
Thanks. I'm trying to get a feel for the general opinion of the result using this (these, I have 7 of them) lens. While I really like 3 & 2, I'm not 100% sure about the whole thing.
I shot all of these by holding the lens unmounted in front of the camera. They were also done in a few minutes after I got home from picking up the lenses. I think with practice, there is potential for these lenses, if I have the patience.
StaticMedia
Joined Dec 2011
Aug 23, 2013 21:58 |  #9
I really like the soft 1960's feel, but you need more DoF.
KirkS518
Joined Apr 2012
Aug 24, 2013 08:29 |  #10
StaticMedia wrote in post #16234971 (external link)
At a focus distance of 2.5", on a 95mm at f/1.3, this is all the dof you can get. :)
navydoc
Gallery: 236 photos
Aug 24, 2013 12:13 |  #11
KirkS518 wrote in post #16227581 (external link)
I worked in the x-ray field for over twenty years so I think the lens is mis-labled. X-rays aren't focused by an optical lens. Typically, the x-ray beam is directed out of the electron tube by the electron beam striking a spinning tungston target set at a 45° angle. The x-rays that get deflected from the target pass through a collumator with lead 'shutters' that can be adjusted to control the size opening that will allow the x-rays to pass through.
X-rays can't be focused onto film or sensor to produce an image like a camera because the x-rays aren't reflected off the object. The film or sensor has to be placed behind the object being struck by the x-rays. The x-ray film is exposed by being struck by x-rays passing through an object rather than being reflected from an object. The image seen on x-ray film is caused by the amount of x-ray able to pass through an object because of its density. The denser the object, the less radiation strikes the film to expose it. It's density that gives an x-ray image the tonal gradation to make it viewable.
KirkS518
Joined Apr 2012
Aug 24, 2013 13:15 |  #12
Hmm. It's a Rodenstock Heligon-XR 95mm f/1.3. The guy I got it from builds x-ray machines like those used at airports. There is (was) a massive flange on it, and from what he was saying (and I wasn't paying full attention), this lens directed the image into a right-angle viewer thing, that then would make it show up on the monitor/TV.
I'll post a pic of the lens later tonight, but basically, this is the lens: (not my image)
http://m1.i.pbase.com …haf.95mmXRHelig​on2635.jpg (external link)
Jarvis ­ Creative ­ Studios
Gallery: 28 photos
Joined Aug 2013
Aug 24, 2013 13:22 |  #13
I like where you're trying to go with it, but it just feels like something you would see on Instagram.
WEBSITE (external link)
Sony ZV-1 || Sony a7RIV || Sony a9 || Sony a1 || Sony FE 20mm f1.8 G || Sony FE 24-70 f2.8 GM || Sony FE 50mm f1.2 GM || Sony FE 90mm f2.8 Macro G OSS || Sony FE 135mm f1.8 GM || Sony FE 200-600 f5.6-6.3 G OSS || Godox speedlights and strobes
KirkS518
Joined Apr 2012
Aug 24, 2013 13:35 |  #14
I wasn't really trying to go anywhere with it. I literally had just gotten home with the lenses, and wanted to see what they produced. These were the most appealing. I hope to experiment with them some more. I may actually weld an adapter to the back of one. These were all done holding the lens in front of the body about 1/2 - 1" away. "Focus" (and I use the term lightly) is achieved by moving the whole lens forward and back, as there is no focus ring. I may try and build some type of adjustable adapter.
Gallery: 28 photos
Joined Aug 2013
Aug 24, 2013 13:37 |  #15
KirkS518 wrote in post #16236230 (external link)
This is the sharpest focus you could achieve? I feel like that lens would frustrate the poo out of me. Even if I was using it just for fun.
2,682 views & 0 likes for this thread, 8 members have posted to it.
1053 guests, 104 members online
