Thread started 21 Aug 2013 (Wednesday) 08:11
Question about T5i write speeds
paintcheck
Joined Jun 2013
Aug 21, 2013 08:11 |  #1
So, after looking at a few other topics somewhat related to my issue, I think I have my answer but I figured I better ask the pro's to be sure. :o
I use the Sandisk Ultra Class 10 cards in my camera however I have noticed that when I attempt to take multiple shots it will stop after 9 and hang for a moment then will allow me to take 9 more. If it's single shot, no problems.
This problem occurs when using raw or jpeg, there's no difference. Common theme on the other threads is that Canon doesn't have the fastest interface to the sd's until you starting getting into the much higher $$ range cameras.
So am I basically stuck with just the 9 limit or would a faster SD help?
Camera(s): 7D, (wishing for a 5dm3)
Lenses: Tamron 70-200 f2.8 VC / Tamron 75-300 f/4-5.6 / Canon Nifty Fifty / Tamron 10-24 f/3.5-4.5
Cards: 16GB/32Gb SanDisks CF
John ­ from ­ PA
Joined May 2003
Aug 21, 2013 09:41 |  #2
Have you looked in the manual for the number of shots in a "burst"? See page 89, burst is 6 images for best raw only and 22 for best jpeg only. Post an image you've taken when you hit the wall and we can likely tell you more, just make sure the EXIF info is intact.
tgara
Aug 21, 2013 10:11 |  #3
abhphotography wrote in post #16227039 (external link)
The T5i supports the UHS-1 standard, which I believe is the fastest available today:
Recording Media
SD card, SDHC card, SDXC memory card
* Compatible with Ultra High Speed (UHS-I) memory cards and Eye-Fi cards.
Are your cards UHS-1 compliant? I think UHS-1 is nearly equivalent to Class 10, but more efficient. UHS cards have special symbols, a U with a 1 in it.
All that said, I think your bottleneck is the number of images the camera can handle in burst. Does the viewfinder show this information? Usually there is a little number on the right side next to the light meter.
EOS 5D Mark III
EOS Rebel SL1
Full Gear List
paintcheck
Joined Jun 2013
Aug 21, 2013 11:15 |  #4
John from PA wrote in post #16227263 (external link)
*facepalm* The manual was the first place I looked but apparently what I was looking for wasn't in the section I thought it was under.. Apparently I need to RTFM again :o
tgara wrote in post #16227359 (external link)
The viewfinder does show a number and its always 9, even taking it down to the lowest quality image, still shows 9.
I don't think my cards are UHS :(
2,758 views & 0 likes for this thread
Latest registered member is countrygirl67
947 guests, 276 members online
