Thread started 26 Jan 2006 (Thursday) 10:29
clouds shot
infinite012
Jan 26, 2006 10:29 |  #1
HTTP response: 403 | MIME changed to 'text/html'
I was walking back to my dorm yesterday and saw that it was snowing a little bit. Then I looked at the sky and thought to myself, "Hey, the clouds look really cool." I took this shot in RAW, but overexposed it a ton (I shot waaaaay to the right). While editing it in Photoshop CS2, I adjusted the exposure, contrast, and saturation to get to the final image you see above. Anyone have any tips for taking better sky/sun/cloud shots? Thanks.
Michael
baldybaldstock
Jan 26, 2006 11:35 |  #2
I really like this. Looks like the polarising filter was let out the bag for this one!!
Canon EOS 40D
Sigma 24-70 F2.8 EX DG Macro
Sigma 70-300mm APO DG Macro
Tokina 12-24 F4
Sigma EF DG 500 Super flash
infinite012
Jan 26, 2006 11:55 |  #3
Thanks, but I didn't use a CP for this shot. I had a UV filter on the kit lens, though, which may have created the flare. The deep blue was from the Photoshopping process.
Michael
baldybaldstock
Jan 26, 2006 12:12 |  #4
Very well done with the post processing since that's not a CP!. Thanks for sharing the pic.
Canon EOS 40D
Tokina 12-24 F4
Dimitri_V
Jan 26, 2006 13:56 |  #5
Well,i don`t think i`m the best person to give you an advice on this as i don`t usualy shoot directly into the sun,i used to though.
Some times i might do , if the sun is realy low (just before sunset/sunrise) but i use ND grad filters to keep the sky from being overexpossed.
I hope that helps.
My site (external link)http://www.earthsbeaut​ytours.com (external link)
infinite012
Jan 26, 2006 14:02 |  #6
Would a ND grad help with this sort of shot though? Perhaps a full ND filter would help more, but then I could've used a quicker shutter speed in the first place.
Please help :) Any advice is helpful.
Michael
Dimitri_V
Jan 26, 2006 16:07 as a reply to  @ infinite012's post |  #7
No,in this case a ND grad would be useless.
I think that if your metering was taken directly from the sun (spot metering) or around the sun (partial) your image would come out alot darker.
Either way i would still bracket it bu 2 stops just to make sure.
And always shoot raw.
infinite012
Jan 26, 2006 16:09 |  #8
Ah, yes. RAW was a life saver for this picture. Is there any sort of ND gradient filter that will only darken the corners of the image? If you've seen the show TopGear then you might know what I'm talking about...
Michael
Dimitri_V
Jan 26, 2006 16:20 as a reply to  @ infinite012's post |  #9
Yes i know what you are talking about,but in this case you need to darken the sun,something like a dark center spot.
I don`t think they exsist yet.
I would just try multiple frames layered in photoshop.
1,097 views & 0 likes for this thread, 3 members have posted to it.
clouds shot
1753 guests, 105 members online
