Thread started 23 Aug 2013 (Friday) 10:54
Requesting calibration data from lens manufacturers
Sens0r
Joined Mar 2013
Aug 23, 2013 10:54 |  #1
This is just an idea that crossed my mind..
I work in military/business aviation industry, specifically in testing lights used in aircraft manufacturing. We keep records of every test procedure of each unit for 10 years in case a customer requests them (i.e the government, or business aircraft manufacturers).
I was thinking, since many of us wonder how good their "copy" of a lens is, why not contact the lens manufacturer and request the calibration/testing data for that copy based on its serial number?
Did anyone try this before?
My profile on 500px.com (external link) | Follow me on Instagram (external link)
Canon 600D | Canon EF-S 18-55mm F/3.5-5.6 IS II | Canon EF 50mm 1.8 | Tamron AF 70-300mm f/4.0-5.6 SP Di VC USD XLD | YN-560II
gjl711
"spouting off stupid things"
Aug 23, 2013 11:05 |  #2
Um.. This is why hammers cost $800 and toilet seats $1000. I'd be really surprised if any records are generated at all or even if every lens is final tested.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
caoko
Joined Aug 2012
Aug 23, 2013 11:43 |  #3
what type of calibration data?
amfoto1
Aug 23, 2013 12:00 |  #4
If each lens were rigourously tested and supplied with that sort of data, they'd cost 3X as much or more!
If you want, you can do a lot of your own testing...
Read the article at http://www.lensrentals​.com …010/11/how-to-test-a-lens (external link)
Then look into http://www.dxo.com/int​l (external link) and their lens testing at http://www.dxomark.com …enses/Camera-Lens-Ratings (external link). They also have camera/sensor testing at http://www.dxomark.com …ras/Camera-Sensor-Ratings (external link)
You can make yourself crazy in search of "perfect" optics (hint: there's no such thing).
Me, I'll just go shoot with my gear and learn what it can do. Crunching the numbers often doesn't really tell us all that much about how a lens will perform out in the real world. Sure, I look at the numbers when I'm considering a purchase, but I take them with a grain of salt, don't put all that much weight on them. Sometimes it's the "flaws" of a lens that make it unusual and wonderful.
5DII, 7DII(x2), 7D(x2) & other cameras. 10-22mm, Tokina 12-24/4, 20/2.8, TS 24/3.5L, 24-70/2.8L, 28/1.8, 28-135 IS (x2), TS 45/2.8, 50/1.4, Tamron 60/2.0, 70-200/4L IS, 70-200/2.8 IS, 85/1.8, Tamron 90/2.5 Macro, 100/2.8 USM, 100-400L II, 135/2L, 180/3.5L, 300/4L IS (x2), 300/2.8L IS, 500/4L IS, EF 1.4X II, EF 2X II. Flashes, studio strobes & various access. - FLICKR (external link) - ZENFOLIO (external link)
Rafromak
Aug 23, 2013 14:17 |  #5
gjl711 wrote in post #16233466 (external link)
Don't be silly:D While I do agree that the existing calibration and testing of lenses and cameras is sufficient for us "picture takers," all parts and equipment used for military and commercial aircraft have to pass strict guidelines, not only for safety reasons, but also because the tremendously expensive liabilities involved.
7D, 5DII
drive_75
Aug 23, 2013 15:07 |  #6
Rafromak wrote in post #16233956 (external link)
Years ago, I worked for a company that buy a decoder for $1000, tested to make sure it meet the military temp and sensitivity spec, repackage in the military enclosure and sell for $9000. This is true. All units passed but just need to verify and prove and then provide the test data.
gjl711
Aug 23, 2013 15:41 |  #7
Yes, I know, I have worked on gov contracts before. The amount of record keeping is staggering and many times redundant.
::Gear::
Rafromak
Aug 23, 2013 16:02 |  #8
drive_75 wrote in post #16234068 (external link)
Yes, and the "proving" part is expensive because your company assumes the possible liabilities. For example, if a company builds an aircraft fuel pump and it is found that the aircraft crashed because the pump malfunctioned, the pump manufacturer will be paying out of his nose in court. Another example: it's found that substandard aircraft engine-mount bolts were used and the engine separated from the aircraft frame...
See my points?
7D, 5DII
Fernando
Aug 23, 2013 16:35 |  #9
We issue Certs of Conformance and keep records for 10 years. Yes, we have to due to some of our certifications and Government requirements.
I wonder if Canon's Cal Lab is ISO Certified?
Fuji convert - Ping me if you have any Fuji gear or legacy glass you're moving.
1,314 views & 0 likes for this thread
Latest registered member is David_Wales
925 guests, 277 members online
