Thread started 24 Aug 2013 (Saturday) 07:22
Shutter failure? (new 6D)
TheNewLegend
Joined Sep 2011
Aug 24, 2013 07:22 |  #1
Hi,
Few days ago I took a photo and the shutter sounded a little bit weird, and the photo is more than half dark.
The 6d has only 2k shutter auctions, and its only 2 months old..
I took another 50 shoots and all came fine, should I be worried or is it a one time thing?
IMAGE: http://img690.imageshack.us/img690/9210/5ypx.jpg
Gallery - DeviantART (external link)
theextremist04
Aug 24, 2013 10:32 |  #2
Are you using flash? Looks like a flash sync issue to me. If it were your shutter it would probably be showing up more consistently.
-Michael
Gear - Flickr (external link) - Website (external link) - Facebook (external link)
Mike ­ Deep
Gallery: 95 photos
Aug 24, 2013 10:40 |  #3
Shutter sounds strange, EXIF says no flash was used. Shutter is toast.
mikedeep.com (external link) - rocket launch photography
amfoto1
Aug 24, 2013 11:48 |  #4
TheNewLegend wrote in post #16235610 (external link)
Hi,
If a shutter is going to fail, it's usually pretty early on.... or after a whole lot of use.
And it's better to have it fail early on when the camera is still under warranty.
You probably have a shutter problem (though it also could be a sluggish mirror problem, just looking at the image). But since this has only happened once, it might be a complete fluke and never happen again.
I'd keep this image on file and continue shooting with the camera, watching for any reoccurance. If it happens again, send the camera off to Canon for repair under warranty. Be sure to include the image examples of the problem. It appears to be an intermittent problem that they might have a hard time replicating when they have the camera.
TheNewLegend
Joined Sep 2011
Aug 24, 2013 13:57 |  #5
I didnt use flash, but maybe its because of fluorescent light? although 1/120 exposure isnt that fast..
I think the shutter sounded like it is on regular mode, and it was on silent mode
If it will happen another time I'll send it to canon.
jhayesvw
Gallery: 167 photos
Aug 24, 2013 19:12 |  #6
I had that happen on my 7d a few thousand pics ago. It did it like 3 times.
I rattled off like 15 shots in 2 seconds to "unstick" everything. No problems since.
One of the guys I shoot with said it happens sometimes and a long burst can "unstick" it all.
Im not sure how 100% correct that is but its worked for me.
My Flickr (external link)
1Tanker
Aug 24, 2013 19:15 |  #7
jhayesvw wrote in post #16236799 (external link)
Sounds like a good idea to me. It will either "unstick", as you said, or will kill the shutter ( which is better now, while under warranty).
Kel
Gear
philwillmedia
Aug 24, 2013 23:05 |  #8
Take your lens off and gently lift the mirror from under the front edge (no, you won't do any damage to it)
You'll be able to see if the shutter has dropped a blade.
Regards, Phil
2019 South Australian Country Press Assoc Sports Photo of the Year - Runner Up
2018 South Australian Country Press Assoc Sports Photo of the Year
2018 CAMS (now Motorsport Australia) Gold Accredited Photographer
Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office"
TheNewLegend
Joined Sep 2011
Aug 25, 2013 05:50 |  #9
1Tanker wrote in post #16236805 (external link)
Thanks for the advice, I shoot 30more frames and none has that problem.
philwillmedia wrote in post #16237311 (external link)
I am afraid to lift the mirror, and what do you mean if the shutter dropped a blade? if it would drop a blade I will notice it at every picture I take
philwillmedia
Aug 25, 2013 07:16 |  #10
TheNewLegend wrote in post #16237821 (external link)
...I am afraid to lift the mirror...
Why?...You won't damage it. It's on a spring, so you're not putting any load on it.
The camera makes it go up every time it takes shot.
You manually doing it is no different.
If you send it to Canon or any other repair tech, that will be the first thing they do.
...and what do you mean if the shutter dropped a blade?...
This
This is my 1D MkII after 187,737 actuations.
...if it would drop a blade I will notice it at every picture I take
You would expect so, but sometimes it doesn't.
Regards, Phil
philwillmedia
Aug 25, 2013 07:19 |  #11
If you don't want to lift the mirror yourself, put it into manual sensor clean mode.
That should show if it's dropped a blade as well.
Regards, Phil
TheNewLegend
Joined Sep 2011
Aug 25, 2013 16:50 |  #12
I just tried the manual sensor clean mode and I ddidnt see a dropped shutters
5,683 views & 0 likes for this thread, 7 members have posted to it.
1674 guests, 166 members online
