Any new updates for the 7D. I went on their site but didn't see any new info. Any behind-the-scenes info? I see that Alpha2 is out, but that's been out for some time.
eddieb1 Senior Member 986 posts Likes: 227 Joined Apr 2013 Location: Oregon More info | Aug 24, 2013 10:02 | #1 Any new updates for the 7D. I went on their site but didn't see any new info. Any behind-the-scenes info? I see that Alpha2 is out, but that's been out for some time.
Aug 24, 2013 13:42 | #2 I am very happy with the autorun version 2013aug20.7d203, you too ? Canon EOS 1Dx / 5D4 / 5Dsr / Fujifilm X-T4 / Lytro illum
CScottIV I should keep some things to myself! More info | Sep 21, 2013 15:00 | #3 This morning I did the autorun from the instructions in the link above. The instructions work and it includes a later version of ML Alpha 2 that supports the modules. Charles
I've been using that as well, it's been working fine. Mostly I've been using the DualISO module. I can't remember what else it on there right now though. Edward Jenner
CScottIV I should keep some things to myself! More info | Sep 22, 2013 07:55 | #5 How do you like dualISO. It looks like some are getting great results but it seems like a lot more effort on the processing side. Of course for moving subjects when there is no time for HDR it is a nice option to have. Charles
CScottIV I should keep some things to myself! More info | Sep 22, 2013 16:49 | #6 Well I did like it. This morning the fresh batteries I put in yesterday were dead! Never had that with the non-boot version. Read something about this a while back so will have to research it. It is an Alpha after all. Charles
Sep 23, 2013 03:09 | #7 C Scott IV wrote in post #16316867 This morning the fresh batteries I put in yesterday were dead! Never had that with the non-boot version. I use the autoboot version also (v2.3.NEXT.2013Aug03.7D203) but never had my batteries run out quick. Canon EOS 1Dx / 5D4 / 5Dsr / Fujifilm X-T4 / Lytro illum
CScottIV I should keep some things to myself! More info | Sep 23, 2013 15:09 | #8 Thank you. It is good to know it isn't happening to everyone. All I could find in the forum so far was to remove the batteries. I believe the build I have is newer but the reports on the forum would have been an older build than you have. Charles
Sep 24, 2013 12:10 | #9 C Scott IV wrote in post #16315812 How do you like dualISO. It looks like some are getting great results but it seems like a lot more effort on the processing side. Of course for moving subjects when there is no time for HDR it is a nice option to have. The effort totally depends on what you use for raw conversion. Basically you just drag the .CR2 file onto an executable and it generates a .dng raw file. If your raw converter can read that, then you just process that instead of the CR2 file. C Scott IV wrote in post #16316867 Well I did like it. This morning the fresh batteries I put in yesterday were dead! Never had that with the non-boot version. Read something about this a while back so will have to research it. It is an Alpha after all. Interesting. I seemed to have a problem with my 7D that it would drain the batteries if left on (which my 5DII does not do) before installing ML. Recently they drained when it was off as well with ML installed. Edward Jenner
Sep 24, 2013 15:37 | #10 Sorry to hijack, only just read about this software. Does it run on a 40d? Instagram
Sep 24, 2013 16:00 | #11 I've heard rumors of the 7D being fried by ML has this been fixed? Canon EOS R5, RF 15-35 f/2.8, RF 70-200 f/2.8, RF 50mm f/1.2
CScottIV I should keep some things to myself! More info | Sep 24, 2013 17:40 | #12 Thanks for the info ejenner. Charles
Snafoo Goldmember More info | Sep 24, 2013 18:12 | #13 jonathanheierle wrote in post #16322230 I've heard rumors of the 7D being fried by ML has this been fixed? Source?
CScottIV I should keep some things to myself! More info | Mar 28, 2014 18:55 | #14 Just FYI for those who have not tried ML on the 7D because the instructions were confusing... They have an installer now! Guess that means it is out of Alpha and into Beta. Nightly compiled, you may try it: http://builds.magiclantern.fm/ Thank you! Installation: 1) Format the card from the camera. 2) Make sure you are running Canon firmware 2.0.3. 3) Copy ML files on the card and run Firmware Update. Uninstallation: 1) Run Firmware Update from your ML card. 2) Follow the instructions. « Last Edit: March 18, 2014, 11:36:15 PM by a1ex »
Charles
PeterWem Senior Member 270 posts Likes: 9 Joined May 2007 Location: Skåne, Sweden More info | Mar 29, 2014 10:27 | #15 C Scott IV wrote in post #16793777 Just FYI for those who have not tried ML on the 7D because the instructions were confusing... They have an installer now! Guess that means it is out of Alpha and into Beta. http://www.magiclantern.fm …ic=9848.msg92351#msg92351 From the first post. For current info beyond that go to page 7 (March 18 and newer) Thanks you lord
| Latest registered member is griggt 665 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
