Thread started 26 Aug 2013 (Monday) 06:09
Tried out my new camera
liquorboxracing
Gallery: 16 photos
Aug 26, 2013 06:09 |  #1
I just bought a 600d and decided to see how it faired at taking night photos of the sky. I found the 6400 iso a bit to slow and yielded a bit to much noise. All of the shots below were taken with iso 3200 with a 10 sec shutter. A couple decent shots for a quick set up in a not so rural area. I can't wait to try some more. I believe I was slightly out of focus in the first shot, but still kind of neat how many stars I actually captured being in the middle of a suburb.
IMAGE: http://i6.photobucket.com/albums/y233/Liquorboxracing/nightpics007_zpsa8ef0537.jpg
IMAGE: http://i6.photobucket.com/albums/y233/Liquorboxracing/nightpics006_zps4e758d74.jpg
IMAGE: http://i6.photobucket.com/albums/y233/Liquorboxracing/nightpics008_zps7cccb4c7.jpg
NCHANT
Joined Jul 2012
Aug 26, 2013 17:35 |  #2
What other settings were you using? Focal length?
The 600D is pretty good at night photography, even in suburbs - this were shot from my back yard:
Orions Belt taken with the 50mm ƒ1.8 - 2.5seconds at 3200 ISO, ƒ2.8
IMAGE: http://farm9.staticflickr.com/8345/8272055408_9211383770.jpg
IMAGE LINK: http://www.flickr.com/​photos/mikeymack/82720​55408/  (external link)
The Pot - Orion's belt (external link) by Mikey Mack (external link), on Flickr
6D x 2 | TM SP 35mm ƒ1.4 | 50mm ƒ1.8 | 85mm ƒ1.8 | 24-105mm ƒ4L USM | 135mm ƒ2L | 200mm ƒ2.8L II | 17-40mm ƒ4L | Sy 24mm ƒ1.4 | Sy XP 14mm ƒ2.4 Flickr (external link) | Facebook (external link)
liquorboxracing
Gallery: 16 photos
Aug 26, 2013 19:09 as a reply to  @ NCHANT's post |  #3
I believe I was at a 18mm with a f4.0 @ ISO 3200and a 10 second shutter. Now that I think about it I could have opened the aperture to f3.5! I forgot!
Would it help me to move up to 50-55mm from 18mm?
NCHANT
Joined Jul 2012
Aug 26, 2013 19:53 |  #4
liquorboxracing wrote in post #16242516 (external link)
18mm would be good for a wider field of stars, say to get the Milky Way, but you can afford to go for a longer exposure :) maybe around 20 seconds, ƒ3.5 and 3200 ISO?
thanboora
Joined Jun 2013
Aug 26, 2013 22:11 |  #5
I also think going up to 20 seconds could give you better result. 10 sec to 20 sec increase should be more critical than opening aperture from f4 to f3.5. Yet, getting enough amount of light is important since you are shooting at such a lightless environment so it should work best prolly at widest aperture and 20-25sec with proper iso level. iso level should not be too high if you are shooting near the city light but if your place is dark enough it can go up to 1600-5000ish. At 18mm,30sec can give you star streaked. But around 25sec, you could get fairly good image of star points.
| SGK | Canon EOS 60D | Sigma 10-20mm |
Gene Kim Flickr (external link)
HughTFall
Joined Sep 2012
Location: RoseOak House, Colwood Lane, Warninglid, Haywards Heath, West Sussex, RH17 5UQ
Aug 26, 2013 23:44 |  #6
"I also think going up to 20 seconds could give you better result. 10 sec to 20 sec increase should be more critical than opening aperture from f4 to f3.5" I agree!
Experienced Product Photographer (external link)!:cool:
liquorboxracing
Gallery: 16 photos
Aug 27, 2013 11:23 as a reply to  @ HughTFall's post |  #7
the photos I took the other night at 20 seconds were not as good as the ones I took at 10 seconds. The 20 second shutter speed yeilded more interferance from the lights in town. Does a lower ISO and slower shutter work better for photographing stars?
the ­ jimmy
Aug 27, 2013 11:57 |  #8
liquorboxracing wrote in post #16244332 (external link)
Yes and no, a lower ISO will reduce noise, however you'll need a longer shutter to let in the same amount of light as a higher ISO and shorter shutter speed. Example ISO 6400 and 10 sec shutter equals ISO 3200 and 20 sec shutter, the light pollution will find you either way. BTW the above values are for example only, I'm not saying those values are equal.
NCHANT
Joined Jul 2012
Aug 27, 2013 16:05 |  #9
You can use high ISO and stack images to eliminate noise? This one is 3200 ISO and only 5 shots stacked:
IMAGE: http://farm9.staticflickr.com/8366/8583440053_1f69f9bbcd.jpg
IMAGE LINK: http://www.flickr.com/​photos/mikeymack/85834​40053/  (external link)
Large Magellanic Cloud (external link) by Mikey Mack (external link), on Flickr
stargazer24
Joined Aug 2013
Sep 02, 2013 02:04 |  #10
NCHANT wrote in post #16245091 (external link)
I so want to be able to get a pic like that someday!
NCHANT
Joined Jul 2012
Sep 02, 2013 06:03 |  #11
stargazer24 wrote in post #16260476 (external link)
You can :) that was taken with the 40mm ƒ2.8 pancake, awesome little lens!
rfdesigner
Joined Aug 2013
Sep 02, 2013 07:59 as a reply to  @ NCHANT's post |  #12
You need to process your images.. there's more in them than you can see at first glance.
I had a very quick process and there's a lot more stars in there as well as lots of JPEG artifacts.
Did you take RAW frames?
Derek
30D, 18~55mm, 100mmf2.0, various Praktica, Atik 383L+ mono & filter wheel, 12" imaging telescope
stargazer24
Joined Aug 2013
Sep 02, 2013 12:37 |  #13
NCHANT wrote in post #16260694 (external link)
How much is that lens?:)
NCHANT
Joined Jul 2012
Sep 02, 2013 14:23 |  #14
stargazer24 wrote in post #16261428 (external link)
Very cheap :) $2/300 here? It's not the best for astrophotography but still gets some shots :)
rfdesigner
Joined Aug 2013
Sep 02, 2013 15:24 |  #15
For AP you don't need autofocus.. it doesn't work, you have to manually focus, so you can use old lenses.
I'm looking at using my old praktica 50mm f1.8 lens with a cheap adapter.. an old FD lens would be fine so long as it's optically still fine.
50mm f1.8s are pretty universal and have been made for a long time with good optics.
4,449 views & 0 likes for this thread, 9 members have posted to it.
1390 guests, 127 members online
