So I was shooting crop for about 4 years before switching to full frame recently with my purchase of the 6D. I'm thrilled with the obvious benefits of increased clarity and resolution as well as the unbelievable low light shooting. But with that being said, the switch also came with some adjustments that were unforeseen. One that I'm running into is with framing and MFD. When I was shooting with my 7D my sigma 35 was an amazing walk around lens. I could even use it almost as a macro lens due to its relatively small MFD. But with the 6D it feels like the description (wide angle). Shots that I would normally go to the 35 for I find myself reaching for my 85. I think that a 50 prime which I found redundant with my 7D would be a help but its just an adjustment.
The other thing I've been running into is that in order to get the same framing that I would get with the crop on the 35 I find myself moving in much closer, very near the MFD. Which creates other issues like a VERY shallow DOF since I am closer to the subject to create that tighter framing. I'm sure that these are things that I'll get used relatively quickly but I thought I'd start a thread to find out if these are things other people on POTN have run into in the past and if there was anything that helped them combat this.
