Thread started 28 Aug 2013 (Wednesday) 06:45
Canon Shutter release
RichSoansPhotos
Aug 28, 2013 06:45 |  #1
Does this Canon Shutter release have the ability to be programmed to hold the shutter for e.g. 4 seconds consecutively for 10minutes, then after that hold the shutter for 2 seconds?
Canon Shutter release (external link)
SouthGalInSF
Aug 28, 2013 07:36 |  #2
Rich, I have this remote and it simply duplicates the on camera shutter button. There is no programmable functions. It just allows you to reduce camera shake by moving the shutter button off camera.
70D | 40D | EOS M | 17-55 IS 2.8 | 70-300 4-5.6 L IS| 50 1.8 II | 55-250 IS | 100 2.8 Macro (non L) |
EFM 18-55 | EFM 22 f/2 | 430EX II
RichSoansPhotos
Aug 28, 2013 11:40 |  #3
SouthGalInSF wrote in post #16246715 (external link)
Yeah, I know what a shutter release does do :cool:
Does anyone know of one that is programmable?
gmikol
Aug 28, 2013 11:50 |  #4
Even the intervalometer (TC-80N3) type controllers are not as programmable as you want.
Depending on your camera, there are probably some remote control apps for smartphones that might do what you want. There's a piece of software for your laptop called "BackyardEOS". It's designed for astrophotography, but it probably does what you need (but it's not free). There might be others like it, as well. You could also look into installing Magic Lantern on your camera. Its intervalometer functions might be that programmable.
Best of luck..
--Greg
NCSA197
Gallery: 153 photos
Joined Dec 2011
Aug 29, 2013 16:46 |  #5
RichSoansPhotos wrote in post #16247387 (external link)
Your second post asks the question you did not ask in your first, which generated the completely appropriate reply quoted.
B & H and Adorama have several different options available here in the U.S. There must be a vendor in your country that handles similar products. You just need to decide how deep your pocket may need to be.....
Jon
Joined Jun 2004
Aug 29, 2013 16:59 |  #6
You want to program the release for one shutter speed for several shots over a set period of time, and then change to another shutter speed? None available that I've ever seen; like gmikol said, you need to look at some of the software-based solutions for that.
Jon
Cocker Spaniels
RichSoansPhotos
Aug 29, 2013 17:09 |  #7
Ok, thanks, I guess I have to set a timer on my iPhone, lol
Heath
Joined Sep 2009
Aug 29, 2013 17:49 |  #8
What are you trying to do? Bulb Ramping? Day to Night?
Heath
"Some photographers push the envelope. Some sit behind a keyboard and criticize their accomplishments." (seen in the comments of a photo article)
Blog (external link)-Twitter (external link)-Zenfolio (external link)-500px (external link)-Pinterest (external link)-Gear List
RichSoansPhotos
Aug 29, 2013 17:51 |  #9
Nowt to do with timelapse photography, its just an event that involves a lot of fireworks after a certain time, a lot more goes off hence I need to make the shutter speed go a bit faster
Heath
Joined Sep 2009
Aug 29, 2013 19:32 |  #10
For what you are doing, the shutter speed should not change, the duration between shots would change.
If you change your shutter speed, you will also have to change either your ISO or Aperture.
My suggestion is to stick with one setting and just set it up to take twice as many photos in the beginning, knowing that you wil probably be throwing away half of them.
Heath
dedsen
Aug 29, 2013 19:38 |  #11
Make sure you get a remote with the right connector for your camera. The one you linked to is for Rebel cameras and will not work with either camera that you show in your profile.
RichSoansPhotos
Aug 30, 2013 03:23 |  #12
Heath wrote in post #16251708 (external link)
Not really, I kept them the same, it depends on the amount of light, I've already done this, the reason for this thread is that I want to do something else while this is going on i.e. edit photos while its being downloaded to computer
5,113 views & 0 likes for this thread, 7 members have posted to it.
1476 guests, 133 members online
