DerDembo wrote in post #16260447
Thanks Jon - I had a GP-E2 in my hands last week and man, this thing is big! So I probably pass on it anyway.
Since I apparently have the local GPS guru on the line: Are you aware of any loggers that look and work pretty much like an USB stick? Preferably single button, press it to turn the unit on/off, nothing else. If I plug it into an USB port it should do two things:
(a) recharge
(b) switch to mass storage device and let me download all tracks as GPS files - exactly like the Garmin eTrexes.
Preferably dead cheap so that I can drop one in each of my bags..
The antenna is one reason they're big. The bigger the antenna, the better able the receiver will be to get a fix. Also, as vk2gwk said, these guys take a lot of power, and the more satellite channels they process at a time (which helps get faster and more accurate fixes) the more power-hungry they tend to be. If I set the GPS on my SX230 to continuous logging, I get only a few hours (even if I don't take any pictures with it). As for dead cheap, forget it. Better just pick up a couple of last-generation (used or reconditioned) eTrexes toward the bottom of the line. Just make sure that whichever model you get does save tracks. Garmin's wrist-watch style (FR-10)recorder has a 5 hr. battery life when continuously tracking or 10 days at 1/2 hr/day (and used as a watch the rest of the time). It's $130 or so. The Foretrex 301's maybe $10 more, but significantly bigger; it does 18 hr. on two AAA cells. I see an eTrex 10 available at around $110 - uses two AA cells and gets 18 hr. on them. Since it supports GLONASS (the Russian stanav system) too, that's what I'd go for as a low-end one.
