Thread started 26 Jan 2006 (Thursday) 18:40
Straightening ?
snappa
Joined Jun 2005
Jan 26, 2006 18:40 |  #1
Another stupid question from yours truly. Can anybody please tell me how to straighten images in PSE3 please. I tried it once and a new window appeared which enabled me to straighten by degrees but I cannot remember how I got to this window.
What happens at the moment is that I click on straighten, in the Image bit at the top, and the image moves very slightly but not to a straight/level plane.
Thank you.
www.pbase.com/snapz (external link)
http://www.johns-snapz.co.uk (external link)
http://Johnssnaps.zenf​olio.com (external link)
tim
Light Bringer
Jan 26, 2006 18:48 |  #2
In CS2 I use the ruler tool, I drag it along the horizon. Then I use image -> rotate -> Arbitary, it puts the right angle in, I hit ok. Then just crop and you're done.
::John::
Gallery: 62 photos
Jan 26, 2006 18:51 |  #3
I wouldn't mind getting it to do that. I follow the same technique in CS2 but I have to fill in the amount of rotation I require - usually several times until I get it right. Is there a setting in options or tools that you know of?
I am the proud owner of the Peleng 8mm Fisheye lens
snappa
Joined Jun 2005
Jan 26, 2006 19:06 |  #4
Don`t worry folks I have found it. Thank you anyway.
tim
Light Bringer
Jan 26, 2006 20:43 as a reply to  @ ::John::'s post |  #5
Don't think there's any settings. Use the ruler, it works out an angle, it's automatically put into the rotate dialog for you.
SWPhotoImaging
Joined Nov 2003
Jan 26, 2006 21:04 as a reply to  @ tim's post |  #6
You can also use the ruler alongside something vertical. It works either horizontally or vertically.
The other simple rotation method is to use the crop tool, drag the crop box out to the size you want, move your cursor outside that box, click and drag around the box to rotate it left or right until it looks straight.
SWPhoto-Imaging
::John::
Gallery: 62 photos
Jan 26, 2006 21:11 |  #7
That is the bit I am having trouble with.
I use the ruler and drag it to the horizon. I then select the arbitary rotation but the pop-up that appears only has the last entry I made - not one worked out automatically by PS
The PS help screen says:
Arbitrary Rotates the image by the angle you specify. If you choose this option, enter an angle between –359.99 and 359.99 in the angle text box. (In Photoshop, you can select CW or CCW to rotate clockwise or counterclockwise.) Then click OK.
I am fine putting in a value - I was just looking for the automatic calculation.
Thanks.
tim
Light Bringer
Jan 26, 2006 21:41 as a reply to  @ SWPhotoImaging's post |  #8
Dunno why mine does it for me, it just seems to.
Yep, that's what I do.
SWPhotoImaging
Joined Nov 2003
Jan 26, 2006 22:28 |  #9
It must be one of those features that's left out of Elements. In CS and CS2 it auto-populates the angle value.
SWPhoto-Imaging
::John::
Gallery: 62 photos
Jan 26, 2006 22:35 |  #10
It was Snappa who had Elements...
Palladium
Jan 26, 2006 22:48 as a reply to  @ ::John::'s post |  #11
straighten right from Adobe Camera Raw (ACR) interface using the straighten tool.
1,436 views & 0 likes for this thread, 5 members have posted to it.
Straightening ?
1596 guests, 118 members online
