Thread started 29 Aug 2013 (Thursday) 09:46
Considering trading my Canon 70-200 f4 for Tamron f2.8 (both non-is)
travisvwright
Gallery: 21 photos
Joined Feb 2013
Aug 29, 2013 09:46 |  #1
What are the pros and cons?
I gain 2.8 which helps me keep my shutter speed up, I guess gives me better subject separation not that that's a problem with the f4.
I lose AF speed I assume, not a killer for me, the fastest thing this is shooting is my 4 year old and I'm ok with a low keeper rate.
I may lose image quality??? how much how bad?
What aren't I considering? List your general thoughts on this idea, please.
I come here for your expert opinion. Please do not hesitate to critique or edit.
70D, 6D, Canon 135, Tamron 28-75 2.8, Tamron 70-200 2.8 VC, Canon 50 1.4, Canon 100 2.8 Macro, Canon 85 1.8, Canon 10-18 4.5 STM
Franklin NC Photographer Travis Wright (external link)
SamFrench
Joined Jul 2011
Aug 29, 2013 10:20 |  #2
It kind of sounds like you 're ok with what you have, and you've identified possible negatve aspects that you'd be ok with - so one has to ask - what has precipitated you thinking about making the trade?
travisvwright
Gallery: 21 photos
Joined Feb 2013
Aug 29, 2013 10:50 |  #3
Because of the Non-IS (and 4 year olds) I need to keep a 200 or faster shutter speed. Being able to drop to f2.8 will allow my ISO to stay usable in darker situations. That's my main reason for considering the switch.
huntersdad
Aug 29, 2013 10:53 |  #4
You could add a flash to help the issue. Or increase your ISO.
I wouldn't do it as the focusing speed is going to be a bigger issue than you think.
Facebook (external link)
http://WWW.BLENDEDLIGH​TPHOTOGRAPHY.COM (external link)
1DxIII x 2 / 24 1.4 II / Sigma 35 1.4 / 85 1.4L / 70-200L II / 300 II / AD600Pros
gnome ­ chompski
Joined Jun 2013
Aug 29, 2013 11:47 |  #5
I have a Tamron 70-200 2.8. Its the one with the older style AF motor. Its loud, clunky and slower to focus than Canon USM lenses. Its not usually a problem if you are semi pre focused, in fact it snaps to focus pretty fast to be honest. But if you fail to lock the focus, it will hunt back and forth all over the place and sound like a cordless drill while doing so. Image quality is good to fantastic, but I did have to dial in a bit of adjustment on my body. Its ok wide open, but not the best. Stopped down to 3.2 or even 4 and it gets pretty sharp. Honestly, I think you would get better results with the Canon you have and just add a bit of fill flash or up the ISO.
Tumblr (external link)
Instagram (external link)
travisvwright
Gallery: 21 photos
Joined Feb 2013
Aug 29, 2013 12:30 |  #6
I don't think a flash helps, I still have to keep my shutter speed up to account for camera shake (using the 1/FL rule). (Correct me on this if the freezing effect of flash makes the rule more flexible).
Hearing that I'd need to stop down to f4 to get the Tam sharp is a bit disappointing but when I needed the f2.8 it'd be there. And if it gets me from ISO3200 to ISO1600 it goes from a nearly terrible to nearly good picture.
gnome ­ chompski
Joined Jun 2013
Aug 29, 2013 15:30 |  #7
dont get me wrong, wide open its not bad. Its just not cream of the crop. Most lenses wide open are not at their sharpest, this one is no different. I use 2.8 all the time.
here's a link to an image I shot with the Tamron 70-200 at 2.8 (external link)
OneJZsupra
Aug 29, 2013 18:35 |  #8
ive used the tamron.... and I hated it. AF was bad, really soft, and the af/mf switching is such a pain because it'll switch to MF all the time.
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
gnome ­ chompski
Joined Jun 2013
Aug 29, 2013 19:51 |  #9
i have used it extensively and never once had it switch to MF when I didnt want it to. Dont hold it there, problem solved. I agree the AF is pretty bad, but its no worse than a kit lens.
OneJZsupra
Aug 29, 2013 23:14 |  #10
gnome chompski wrote in post #16251752 (external link)
If kit lens we are talking about the 55-250? Because I don't think those two compare. I would compare to the 70-200 f4
dannybres
Joined Apr 2012
Aug 30, 2013 03:36 |  #11
travisvwright wrote in post #16250551 (external link)
Not with a flash, the flash duration is tiny compared with your shutter speed. It will be ok that is unless you get into fill flash etc.
For me, id keep the Canon lens and add a speedlite.
EOS 7D, EOS M, EF-S 17-55mm f/2.8 IS USM, EF 70-200mm f/2.8L IS USM, 430EX II.
1,753 views & 0 likes for this thread, 6 members have posted to it.
1509 guests, 131 members online
