Thread started 29 Aug 2013 (Thursday) 13:02
Small studio setup with 2 speedlites
bugler
Joined Aug 2013
Aug 29, 2013 13:02 |  #1
I tried this last night and I wasn't able to get it set up in a satisfactory way. Is there some advice on how to make this work? I was trying to use one on my model and one to kill shadow on my paper backdrop. I tried different power settings and all that. They are both on stands with triggers. The backdrop is off white. The background light was a 430ex2 and the main light was a 580ex 2. Thanks for any advice.
Bodies: 6D, EOS-M, & 1Ds(for sale)
Lenses: 17-40 f/4L, 24-105 f/4L IS, 80-200mm f/2.8L "Magic Drainpipe", 40mm f/2.8 stm Pancake, 50mm f/1.4, Ef-M 22mm f/2 STM
BrickR
Joined Mar 2011
Aug 29, 2013 16:25 |  #2
What modifiers are you using? Without knowing what look you're going for I'll just throw some ideas out there:
If you are trying to do high key, you need to light the backdrop separately, meaning 1 speedlight on its own, leaving one speedlight for the subject, so you might want a speedlight and reflector for the subject.
If you are using both speedlights on your subject, you're going to get a low key or grey looking backdrop from the light fall off. No way around it unless you have your subject right up on the backdrop.
You could pick up a cheap manual flash or 2 like a YN 560 and use those to light your backdrop.
My junk
The grass isn't greener on the other side, it's green where you water it.
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Aug 29, 2013 16:27 |  #3
It would be helpful in addition to letting us know if you are using modifiers (softboxes or umbrellas) if you could post a couple shots of your results. Its often easier to see the error than anticipate the problems.
JeremyKPhoto
Joined Apr 2012
Aug 29, 2013 16:31 |  #4
I tried using 2 speedlites in a studio setup with umbrellas and softboxes. Eventually I added a third, and now a fourth. Much better with four of them lol. Just pick up some manual flashes for about $60.
5D Mark III / 70-200 2.8L IS II / 24-105L / 50 1.8 stm / Tamron 70-300 VC / Sigma 85mm 1.4 Art
bugler
Joined Aug 2013
Aug 29, 2013 17:47 |  #5
No modifiers. But I just ordered a 300 w/s strobe with a large grid soft box. Should work fairly well for my setup. And I ordered a soft box for one of the speedlites. I also have a large circular reflector/diffuser I can hang somewhere if need be.
And I don't think I can post what I tried to take last night. My other half is a freelance nude model and I think this isn't a nsfw forum.
I'm looking for just casual "artistic" stuff. I have a slightly off white paper background so I can do either high key or go for something else. My 430 was just blowing out the background and still didn't get rid of the heavy shadows from the other light. Just ordered a black paper backdrop too so I think I may get better results with that. Sorry, I'm used to only using studios set up by other people so any advice is highly appreciated.
Submariner
Joined May 2012
Aug 30, 2013 06:28 |  #6
Think you might have fun with a Studio Strobe and a 430II!
Personally if I was you - either go studio strobes or Canon Speedlites.
I compromised inside I use 3 Bowens Studio Flashes and one Yn560II (cheapo flash) to illuminate the backdrop.
Outside I use an STE3 to trigger 2 600EX RTs in ETTL2 mode and the Yn 560II to illuminate background or fill to taste.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
gonzogolf
Gallery: 561 photos
Aug 30, 2013 09:54 |  #7
bugler wrote in post #16251448 (external link)
Unmodified flash in a small studio means hard shadows. There is really no way around it. Many new users think you can add extra lights to kill shadows but its important to remember that each light you add creates a new shadow somewhere. Its much easier to increase the size of your light source with a modifier which is the key to soft light. Then you can work on balance to better control shadows.
bugler
Joined Aug 2013
Aug 30, 2013 12:47 |  #8
Ok, I just got this light (external link) in the mail today. Coupled with a 430ex 2 and a yn560 2 (for some reason thought i had a canon 580...) and either white or black paper background, will I be able to put together a semi-respectable small studio? I have triggers for all flashes and they are all on stands.
gonzogolf
Gallery: 561 photos
Aug 30, 2013 13:16 |  #9
bugler wrote in post #16253722 (external link)
You can make the gear work, although it still comes back to modifiers for the speedlights. The disparity in power between your strobe and your speedlite may also be an issue as well. But the problems from here on out are not so much gear related as knowledge related.
bugler
Joined Aug 2013
Aug 30, 2013 13:28 |  #10
I guess I'll just have to spend some time down there and just shoot a bunch till I get what I want. I'll have a small strap on softbox for one of the speedlites but that's really it for modifiers.
gonzogolf
Gallery: 561 photos
Aug 30, 2013 13:31 |  #11
Size matters. Strap on boxes dont increase the size significantly. Get some umbrellas and start there.
gonzogolf
Gallery: 561 photos
Aug 30, 2013 13:32 |  #12
Youtube can be your friend here. B&H photo has videos as well on lighting. AdoramaTV is helpful as well.
tkbslc
Aug 30, 2013 13:37 |  #13
bugler wrote in post #16253835 (external link)
I would pick up a couple of 40" convertible umbrellas (And brackets and stands if you don't have them). Those are big enough to make a real difference, yet small enough to be portable. Pretty cheap, too, for all the difference they make.
I like this one for the money: http://www.adorama.com​/LTU40BC.html (external link)
Taylor
EOS Rp | iPhone 11 Pro Max
bugler
Joined Aug 2013
Aug 30, 2013 13:39 |  #14
tkbslc wrote in post #16253867 (external link)
I'll definitely look into that. Thank you!
1,445 views & 0 likes for this thread, 6 members have posted to it.
1264 guests, 172 members online
