Thread started 30 Aug 2013 (Friday) 03:23
Macro or Tele
davidfarina
Gallery: 43 photos
Joined May 2013
Aug 30, 2013 03:23 |  #1
Hey guys once again its me :)
Im thinking since a long time about adding two lenses. A macro and a tele. My affordable choices would be:
100mm 2.8 L macro
70-300 4-5.6 L
Now: which one should i buy first, since i only can buy one at the moment..
Looking at my gear what do you think will fit best as next lens?
Sony A7RII | Sony A7S
EF 40 | EF 70-300L | FD 35 Tilt-Shift
FE 16-35 | FE 28 | FE 90
CV 15 4.5 III | CV 40 1.4 MC | Summilux 50 ASPH
Website (external link) | 500px (external link)
YashicaFX2
Joined Aug 2013
Aug 30, 2013 03:30 |  #2
I don't think looking at your current gear gives us any clue at all about what lens you should buy. Perhaps some information about what you would like to shoot, but can't, with your current gear would help. But, if you had that information, you'd have your answer, wouldn't you?
Dedicated APS-c shooter. Gripped 60D, 60 2.8, 10-22, 15-85, Σ70-200 OS and a big white something or other! Plus a 5D w/28-75.
davidfarina
Gallery: 43 photos
Joined May 2013
Aug 30, 2013 03:36 |  #3
YashicaFX2 wrote in post #16252584 (external link)
Sure i know what to shoot. The problem is i want to shoot macro as much as i want to go longer for moon/astro shots aswell as travel lens with its long reach and portability of the 70-300L.
Or are there cheaper options to get similiar quality?
YashicaFX2
Joined Aug 2013
Aug 30, 2013 03:57 |  #4
I don't do macro, so I have no relevant comments about that.
As far as telephoto goes, I wouldn't find the 70-300L long enough. I have the 100-400L and find it too short sometimes, whether on the 5D or 60D. The 70-300L is reviewed to be much sharper, with faster focus and better IS than the 100-400L. It is also smaller, lighter and uses a rotating, not trombone, zoom. The IQ of the 100-400L is easily good enough for me. It's implementation of IS is somewhat antiquated and ineffective. It is just not much help where you need it most, at 400mm. I get a stop, perhaps 2, once in a while. That said, shooting at 400mm is completely different than shooting at 100mm. There is a bit of a learning curve involved. As most folks buy a telephoto for reach, I would suggest foregoing the higher IQ of the 70-300L for the longer 100-400L. Your needs may not match mine, however.
davidfarina
Gallery: 43 photos
Joined May 2013
Aug 30, 2013 04:06 |  #5
YashicaFX2 wrote in post #16252617 (external link)
For things far away it cant be long enough i believe you. But the push-pull zoom on the 100-400 paired with its old IS system is an indicator for me, that i wont be satisfied with it. I may lose 100mm reach but on my 650D its something like 480mm which is much more than i have now and should suffice for what im doing. Im not going to do high-end wildlife shots or so, its just nice to have a lens which is very versatile (which i think the 70-300 is).
Still unsure which lens to get first :S
I think i should take the tele first as i dont have something like that right now (while i already have a lens covering something near 100mm). On the other hand i see that i want to get into macro as i like to do that since a time...
YashicaFX2
Joined Aug 2013
Aug 30, 2013 04:30 |  #6
I think I would go with the tele first, whichever one you choose. The MFD on the 100-400 is about 6 feet. You can do some flower and bug work with that lens if you shoot near MFD and at 400mm. I don't know the MFD of the 70-300L.
Just curious. Why are you considering the 100L macro instead of any of the other three?
hollis_f
Aug 30, 2013 04:37 |  #7
davidfarina wrote in post #16252592 (external link)
The 70-300 will barely be long enough for Moon shots. You need around 2500mm to fill a FF image with the Moon. And for any other Astro shots you want to be wide angle (for Milky Way, Startrails, Constellations) or have a tracking mount.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
davidfarina
Gallery: 43 photos
Joined May 2013
Aug 30, 2013 05:05 |  #8
YashicaFX2 wrote in post #16252654 (external link)
Which other macro lenses? the 60mm is too short i think. Ill have to come very close to my subjects.. Then the 50mm 2.5 isnt a "real" macro since 1:2. The 180mm macro is a bit over my budget and only just f/3.5 which is a pitty when i want to use it as a portrait lens from time to time. Have i forgot something?
davidfarina
Gallery: 43 photos
Joined May 2013
Aug 30, 2013 05:06 |  #9
hollis_f wrote in post #16252662 (external link)
Its less to fill the frame with the moon more just for fun because with the 135mm on crop i cant see even the moon xD
Also it would be nice to have a long lens for interesting compression shots
paddler4
Aug 30, 2013 06:58 |  #10
That depends on what kind of macro you are planning to shoot and which of your bodies you intend to use for macro, which you haven't said. One of my macro lenses is the 60mm, and I get a lot out of it. However, assuming ~100mm is a reasonable length, there are several high quality cheaper alternatives, including the Canon 100 non-L, which costs half as much and is virtually as good optically. I own the 100L, but I think it is steep for a novice, given that you won't know until you gain some experience whether you actually enjoy macro (which is very demanding).
Check out my photos at http://dkoretz.smugmug​.com (external link)
davidfarina
Gallery: 43 photos
Joined May 2013
Aug 30, 2013 07:07 |  #11
paddler4 wrote in post #16252843 (external link)
I want to use both lenses on my t4i to get most magnification/reach out of it. However the 70-300 could be used on the fullframe too since it is a very versatile FL.
The 100 non-L lacks IS which i think might be a nice feature
YashicaFX2
Joined Aug 2013
Aug 30, 2013 07:53 |  #12
davidfarina wrote in post #16252688 (external link)
The 180 macro at f/3.5 will do a better job of blurring out the background that the 100L at f/2.8. I think I heard somewhere that it focuses very slowly though.
davidfarina
Gallery: 43 photos
Joined May 2013
Aug 30, 2013 08:37 |  #13
YashicaFX2 wrote in post #16252934 (external link)
Okay maybe, but i dont think i would use it much since 180mm is a strange focal length. The 100mm is more versatile and not only focussed to macro work. At the second point when i get the 70-300 i dont need a lens as long as 180mm..
DreDaze
Gallery: 49 photos
Aug 30, 2013 09:47 |  #14
do you have a flash? you'll need one for macro...
I'd rather have the non L and a flash, than just the L
Andre or Dre
gear list
Instagram (external link)
amfoto1
Aug 30, 2013 10:12 |  #15
If you stick with the L, you might want to get the 70-300L first. You can always get some macro extension tubes to use with it, to be able to focus much closer, at least near macro. But, I agree... it's not really long enough for moon shots and not the type lens you're very likely to use for astrophotography. It's also not really long enough for a lot of wildlife, particularly smaller critters and birds.
The last thing you have to worry about with macro photography is bluring down the background. In fact, at higher magnifications you'll be struggling to get enough depth of field, not looking for less. Below was shot with a 90mm lens at f11.... the background is a sidewalk and ugly trash can. As you can see, the background blurs away to nothingness...
IMAGE: http://farm6.staticflickr.com/5047/5283068637_5fb71ef4e8_b.jpg
IS on a macro lens is kind of silly, IMO. If you get serious about macro, you'll be using a monopod or tripod a lot of the time... Or flash. All of which make IS, which is nowhere near as effective at higher magnifications anyway, less necessary. On the 100mm, IS is most useful when using the lens for non-macro purposes (and you already have a 135L, which you'll probably be using instead for it's faster AF performance.) I would not spend the extra money for IS on the 100mm. I'd put the money saved into a tripod mounting ring for the lens, which is far more practical for macro work. The image quality of the 100L vs the 100/2.8 USM is virtually identical. Both are excellent. The build quality of both is top notch, too. Even though it's not an L, the 100/2.8 USM is identical build to the 180/3.5L. IMO, the most significant difference between them are that the 100/2.8 USM's lens hood is rather large (and is sold separately)... and the 100L has a somewhat enhanced Focus Limiter feature (three ranges, vs two on the non-L). Because I rarely use my 100 Macro for non-macro purposes, the IS doesn't do much for me, so I won't be upgrading any time soon (unless I win the lottery and just have money to burn).
You really might want to consider an alternative.
For less than the price of the 70-300L ($1400 US) or little more than the 100L alone.... you could get both the 70-300 IS USM (non-L, $450 US) and the 100/2.8 USM ($550 US) plus their lens hoods (unlike the L, sold separately: $44 and $33, respectively, or less if you buy Chinese knock-offs). The tripod ring for the 100/2.8 USM runs about $160, while for the 100L it's about $190, for Canon OEM in both cases. There are Chinese knock-offs for either one, that cost about $50.
Another alternative would be the 70-300 DO IS USM, which is more compact. But it's close to the same price as the 70-300L.
Comparing images from the three 70-300s, you will have a really hard time telling them apart. All three actually have quite good IQ. They also all have fast AF.
The differences are:
Build quality of the 70-300L is definitely the best. Of course, at 3X the price, it had better be.
The 70-300 DO is quite a bit smaller and lighter, unfortunately it's IS isn't as effective as the other two.
The 70-300 IS USM (non-L, non-DO) is slightly longer than the DO, but actually weighs less. It's a little plasticky, Canon mid-grade quality. Although it's got fast, accurate USM focus, it's somewhat a hybrid because it can't do FTM or Full Time Manual override of focus. You have to turn off AF at the switch before manual foucsing the lens (and the focus ring rotates during AF).
But, again, you won't see any significant difference in your images.
Later, if you find you use either or both these lenses a lot and they meet your needs really well, you can upgrade if you wish.
Yes, the 180/3.5L macro does blur down backgrounds strongly. In fact it's got potential for incredibly shallow depth of field, as you can see here...
IMAGE: http://farm6.staticflickr.com/5093/5585285923_f2d1d237aa_b.jpg
The 180mm is a considerably more difficult macro lens to work with, than either of the 100mm. The 180mm is more of a dedicated macro lens, less likely to be handy for non-macro purposes. One reason is that it's AF is rather slow, even when the Focus Limiter is used. I rarely use this lens on crop... it's too long. At high macro magnifications, it's going to largely be done on a tripod (well, above image wasn't, but camera and lens were sitting directly on the ground). Due to the shallow DOF this lens renders, it's more likely you'll need to stop it down quite a bit, requiring slower shutter speeds (or higher ISOs or flash, or some combination of these).
The 60mm Macro is an EF-S lens, so won't work on your FF camera, only on your cropper. The same is true of the Tamron 60mm, which I'm trying out right now (it's an interesting lens because it's a full stop faster than nearly all other macro lenses... f2.0).
Yes, the 50/2.5 Compact Macro only goes to 1:2 on it's own. Either with macro extension tubes or it's dedicated 1:1 adapter, it can be boosted. But it's still a fairly short focal length to try to use for general purpose macro.... it can put you too close to skittish subjects... or ones that sting or bite. Or with inanimate subjects, you might have problems casting shadows or bumping them with a lens hood.
In my opinion, 90mm to 105mm is the most versatile "all around" macro focal length. That means in addition to the two Canon 100mm, there are also the Tamron 90mm (two versions, incl. a new one with stabilization and a new, faster AF drive), Tokina 100/2.8, and Sigma 105/2.8 OS.
Personally I really like the Canon 100s because they can optionally be fitted with tripod rings, are internal focusing (don't grow longer when focused closer), and have all the goodies in one package.
I consider 150mm and 180mm macro lenses to be largely "full frame"... a bit long and harder to use on crop.
2,952 views & 0 likes for this thread, 9 members have posted to it.
Macro or Tele
1605 guests, 142 members online
