Hello There,
I just purchased a one year membership to Chromasia (www.chromasia.com
), which I've thought about in the past and finally decided to give it a go. I find David Nightingale's approach to image editing is quite amazing and thought-provoking to say the least; impressive stuff.
Something I've noticed in all his edits is that when he converts to black and white, usually via channel mixer or b&w adjustment layers, the black and white conversion is always being placed in a position pretty high up in the later stack. He uses a lot of local masked curves for particular contrast adjustments (usually between 6 and 10). The following is a typical layer order - I will describe it from the bottom/background layer up:
Background image
Copy of background for cloning etc.
Local curve contrast 1
Local curve contrast 2
Local curve contrast 3
Local curve contrast 4
Local curve contrast 5
Local curve contrast 6
Channel Mixer greyscale conversion
Global curve for subtle color toning
My question is, is there any difference or benefit to having all of your contrast and luminance adjustments placed below your greyscale conversion, or vice-versa?
I have always loaded my base color image into Photoshop, then performed my duplicate layer for cloning, then gone straight into black and white so that all adjustments above are affecting the greyscale image, rather than the greyscale image affecting all the adjustments below. Or maybe it doesn't matter and they are affecting one another equally regardless?
-Randy
