Hi everyone,
Just a Quick question, I assume that 622c when attached on hotshoe will control off camera 600EX-RT directly as the ST-E3 RT does. i mean without attaching the 622c with the flash. Am I thinking right??
regards
Faisal
Aug 31, 2013 13:04 | #1 Hi everyone, Canon 5D Mk III, Canon 8-15mm f/4L, Canon 11-24mm f/4L, Canon 16-35mm f/2.8L II, Canon 24mm f/4 TS-EL, Canon 35mm f/1.4L, Canon 24-70mm f/2.8L II, Canon 85mm f/1.2L II, Canon 100mm f/2.8L IS, Canon 70-200mm f/2.8L IS II, Canon 200mm f/2L, Canon 300mm f/2.8LII, 3xCanon 600EX-RT, Lowepro Vertex 300 AW
oldvultureface Goldmember More info | You'll need another YN-622C attached to the 600EX-RT. The two aren't compatible radio-wise.
Sep 01, 2013 14:43 | #4 oldvultureface wrote in post #16256516 You'll need another YN-622C attached to the 600EX-RT. The two aren't compatible radio-wise. Trailboy wrote in post #16256505 Nope. Thanks guys Canon 5D Mk III, Canon 8-15mm f/4L, Canon 11-24mm f/4L, Canon 16-35mm f/2.8L II, Canon 24mm f/4 TS-EL, Canon 35mm f/1.4L, Canon 24-70mm f/2.8L II, Canon 85mm f/1.2L II, Canon 100mm f/2.8L IS, Canon 70-200mm f/2.8L IS II, Canon 200mm f/2L, Canon 300mm f/2.8LII, 3xCanon 600EX-RT, Lowepro Vertex 300 AW
| Latest registered member is ealarcon 1141 guests, 170 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
