Thread started 31 Aug 2013 (Saturday) 15:46
Fd on eos
calypsob
Joined Jan 2012
Aug 31, 2013 15:46 |  #1
As I understand an fd- eos adapter without the correction lens will not allow infinity focus. This is no issue for macro so I have considered the 50mm FD f/3.5 macro lens by canon. As I understand it has excellent field flatness and it looks baffled on the front in a way quite similar to the mpe-65mm. Has anyone on here used the 50mm f3.5 macro? Im not sure what the magnification ratio is for this lens but I have some extension tubes on standby so I am hoping to at least achieve 1:1 magnifications, it will be good to have a nice sharp dedicated macro.
Wes
Gear: Many gears Yes.
Jappe
Joined Aug 2012
Sep 01, 2013 09:15 |  #2
I have used 50mm FD macro in my EOS bodies, mainly with FD bellows. It has 1:2 magnification and with 25mm extension magnification is 1:1. For higher magnification ratio you can use FD reverse rings that are easily available f.ex. from ebay.
50mm FD macro has very long focus rotation, so I find it very nice for macro use since sharp point is easy to find. I couln'd find too much IQ difference between 50mm FD macro and 50mm EF compact macro. For the money 50mm FD macro has good value.
calypsob
Joined Jan 2012
Sep 03, 2013 01:39 |  #3
Cool thanks for sharing. The one I am looking at comes with extension tubes. The macro version of the 50mm fd has an extra element designed to keep the field as flat as possible. I am trying to avoid going back to reversed lenses due to the very small working distances.
Wes
1,404 views & 0 likes for this thread, 2 members have posted to it.
Fd on eos
1606 guests, 140 members online
