So I'm not sure if it's user error, or crappy equipment.
I'm using a 720nm filter, just to experiment/play around with IR. I know I have to set a custom WB to be able to properly manipulate things in post. I've taken a shot of healthy green grass to set my custom WB to, both with the IR filter, and without, but I continue to have issues with color. Swapping red & blue channels hasn't resulted in the renditions I was hoping for, as I usually end up with a purple image. If I know which way to go with setting the custom WB, at least I'll be starting in the right place, and take it from there.
Do you set the WB with the filter on, or set it with it off?
