So I'm trying to eliminate the need for sync cords. I have a Norman 24/24 with BD, and a Norman ML600. The 24/24 and the ML600 have optical triggers. The ML is a slave optical trigger. The BD is hard-cabled to the 24/24, and the ML600 is on it's own power. I also have a set of YN622's, a few 602's, a YN568EX, YN467, and a slew of other manual flashes.
I'd like to be able to fire the Norman stuff without the use of sync cables, seeing as they can be fired with the optical sensors, how can I set it up? I won't use an on camera flash for this (as a light source, but as a trigger I'm ok with that if possible), and I won't be using TTL (obviously).
Camera is a 50D. Any ideas how can I do what I'm hoping to do?
