Thread started 27 Jan 2006 (Friday) 14:49
script to resize for forums
vjack
Jan 27, 2006 14:49 |  #1
I wrote a script PSCS2 script to resize photos to meet the requirments of this forum, but it isn't getting the pictures quite small enough. Basically, I convert to 8-bit sRGB, resize to 800px, sharpen, and save as jpeg. However, in order to get the file size under 100K, I have to use what seems like a very low quality jpeg. Have any of you written a similar script, and if so, where did you set your compression?
Canon 20D
Canon EF-S 10-22mm f/3.5-4.5 USM
Sigma 18-125mm f/3.5-5.6 DC
Tamron 28-75mm f/2.8 XR Di LD
Canon EF 50mm f/1.8 II
Canon EF 70-200mm f/4L
Canon EF 100-400mm f/4.5-5.6
L IS
Canon Speedlite 430EX
Manfrotto 3021BPRO; Kirk BH-1 ballhead
Canon Pixma 4200
< see my gallery (external link) >
jfrancho
Jan 27, 2006 14:59 |  #2
What about a smaller dimension that would allow you better resolution/quality?
tommykjensen
Gallery: 6 photos
Joined Mar 2004
Jan 27, 2006 15:01 |  #3
Do You include EXIF data? That alone takes about 15Kb.
EDITING OF MY PHOTOS IS NOT ALLOWED
vjack
Jan 27, 2006 15:10 as a reply to  @ tommykjensen's post |  #4
Okay, I'll set it at something like 700 or 750 px and see if that helps.
Canon 20D
L IS
Canon Pixma 4200
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Jan 27, 2006 15:16 |  #5
I have a saved action that I use, it resizes and adds USM and has the option of adding a background script with EXIF info in it.
Then I just manualy choose save as, and select the required quality to get the file sizes to where I need it.
The problem with Digital images is the subject has such a huge effect on how big the file will be. A photo of a white wall will be much smaller than a brightly coloured flower garden.
So you either need to set the script to work with your largest file sizes and accept that the smallest will be smaller than they need to be, or stick with manualy changing them.
Of course if your batch processing then it can be a lot easier to choose the former.
And when I have done this I just batch proccess with another action I have which does a Save As.
So long and thanks for all the flash
Robert_Lay
Jan 27, 2006 23:58 |  #6
It has been my experience that with approximately 800 x 600 pixel virtual image size, it requires a quality setting of 3 - 5 in order to be under 100kB. Unfortunately, there is no way to predict exactly, because jpg files compress more when they contain blah pictures (i.e., pictures with little detail).
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
jfrancho
Jan 28, 2006 00:03 as a reply to  @ Robert_Lay's post |  #7
Robert_Lay wrote:
blah pictures
LOL. You're usually a little more descrptive than that! It must be late. :)
vjack
Jan 28, 2006 08:03 as a reply to  @ jfrancho's post |  #8
You guys are right. I think I'll just do a resize and sharpen action and do the save manually.
Canon 20D
L IS
Canon Pixma 4200
Robert_Lay
Jan 28, 2006 09:56 as a reply to  @ jfrancho's post |  #9
Yeah, you're right - it was about Dark +2 when I wrote that.
Bob
1,319 views & 0 likes for this thread, 5 members have posted to it.
1596 guests, 118 members online
