Thread started 07 Sep 2013 (Saturday) 21:13
any DIY manual to fix top scroll dial on 5D2?
the.forumer
Joined Oct 2011
Sep 07, 2013 21:13 |  #1
my 2 year old 5d2 is facing an annoying issue right now - the top scroll dial (used to change ISO usually) sometimes doesn't engage the gears (there should be a clicking sound) when scrolled to the left. it always works when scrolled to right though.
called Canon and they are charging me US200 just to replace the dial alone. in view of the exorbitant charges, is there any chance that i could DIY and fix it myself? would need some instructions and sources for the components. at the same time, perhaps i could fix the "creaking body" issue as well.
let me know if anyone has the expertise on this matter! :)
mjww
Sep 08, 2013 09:00 |  #2
I don't have a 5D2 but could it be the rubber ring that is over the dial is slipping, hence the click to change your setting is not being made?
Equipment list - According to the wife - "how many more lenses do you need? Yet another camera?"  ???
Shane ­ W
Sep 08, 2013 09:16 |  #3
Did you buy the camera NEW from an authorized retailer and have the receipt? The might treat it as a warranty repair. Might being key word here. Otherwise would you want to risk screwing up your camera royally by trying DIY repair on a camera that you might have paid $2k for? Send it in to Canon with your documentation and see what they say. If they need to bill you $200 for a proper repair, bite your lip and pay it! Yea, I wouldn't want to spend the coin myself but if I had to to fix my camera, I would, for sure.
Shane W
70D | Sig 10-20 | EF-S 15-85 | EF 70-200 2.8L | Sig 150-500 | Viv 28 2.5 | Sig 30 | Tak 50 1.4 [COLOR=blue]| EF 100 2.8 Macro | 1.4x TC | Nodal Ninja 3 | Tripods | Some Flashes | My flickr  (external link)
Vixen89
Sep 08, 2013 09:23 |  #4
My old post:
HEY! You have the same problem I had a few days ago on the 30D and fixed it for my boyfriend!! Here's the threads I read to fix it, your shutter wheel isn't turning / clicking all the time right? It feels like it's slipping or sliding and not changing your shutter speed. This is your solution! The rubber wheel is not in contact with your plastic wheel that it rests on so like most people who fixed it themselves rather than send it into Canon:
1. Shine a flashlight down into the shutter wheel area and you'll notice that there's a plastic piece under the rubber.
2. You lift the rubber wheel using a toothpick, needle, paper clip or whatever is thin enough to clear into the camera.
3. Put some super glue on the plastic wheel via using another toothpick, needle, paper clip and etc...BE CAREFUL not to let the super glue drip anywhere else but into the groove of the plastic wheel (like a tiny drop).
4. Let it sit for 10 mins. and it's good as new!!
5. THANK YOU POTN FOR FIXING MY CAMERA! and happily want to share it with you.
https://photography-on-the.net …/showthread.php​?t=1081702
http://forums.dpreview​.com …age=36643925&ch​angemode=1 (external link)
Read those two threads and it's the same method I used to fix mines. Good luck! I didn't see a reason to send it to Canon for a minor fix. I'm a DIY'er person, just like fixing my car, I like to fix my camera. xD
HOPE THIS HELPS!!
I'm actively lazy!! :D | Gear List | photovxn.com (under construction)external link
the.forumer
Joined Oct 2011
Sep 10, 2013 19:16 |  #5
do u have any pictures/vid to show? i tried prying it open, but still can't see the plastic wheel!
yes, i have the exact problem which u described. really appreciate that u came forward to share the fix.
can't believe canon wants to charge a bomb for such a simple fix though.
Vixen89
Sep 10, 2013 19:30 |  #6
the.forumer wrote in post #16286236 (external link)
I'll try and get photos when I get a chance. Thanks for being patient with me!
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Sep 10, 2013 22:06 |  #7
there's a useful description with photo's Here (external link)
TF posting: here :-)
the.forumer
Joined Oct 2011
Sep 11, 2013 02:57 |  #8
joeseph wrote in post #16286684 (external link)
got it! did a 'torture test' for 2 minutes and the sliding problem seems to have disappeared. will update soon.
thanks everyone for helping! can't believe i saved 200 bucks with this easy fix! phew!
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Sep 11, 2013 04:26 |  #9
I am quite sure canon fixes this correctly, and not with a bubble gum and duct tape solution. This means taking the camera apart and replacing parts. The quick fix is the option the consumer can take, but canon won't.
Frodge
Joined Nov 2012
Sep 11, 2013 06:24 |  #10
How common is this failure? I always thought those wheels were just plastic. Bad engineering to put rubber over plastic on a part that needs to grip and click in detente.
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
2,495 views & 0 likes for this thread, 7 members have posted to it.
1501 guests, 134 members online
