Hi,
I promised myself I would get to grips with Layers this year. Can someone please explain in laymans terms the difference between an "adjustment layer" and a "layer mask"
Ian
PS, I'm using elements 11
Sep 08, 2013 06:04 | #1 Hi, Ian
Kolor-Pikker Goldmember 2,790 posts Likes: 59 Joined Aug 2009 Location: Moscow More info | Sep 08, 2013 07:10 | #2 Basically an adjustment layer is a standard photoshop manipulation, like curves or hue/saturation, but you can edit it any time after the fact. So if you just hit CTRL+M for curves, and apply, you can't change it anymore, with adjustment layers, you always have the adjustment available to change. 5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
Sep 10, 2013 18:36 | #3 Thanks for your detailed post. Very informative and has answered my question. Ian
Sep 10, 2013 19:56 | #4 A mask is not actually an adjustment or edit of any kind - it simply lets you dictate which parts of the image you want your adjustments or edits to show through on. Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
Sep 11, 2013 16:51 | #5 Duplicate Post ( sorry ) Ian
hihohito Member 225 posts Joined Oct 2010 More info | Sep 11, 2013 17:17 | #6 Me thank you to for the explanation.
Sep 16, 2013 17:32 | #7 Thanks RandMan ( I replied to you the other day but deleted the wrong post :0 ) Ian
Sep 16, 2013 20:18 | #8 tons of online resources and tutorials, if you prefer a book, I like a book called - surprise! - Layers by Kloskowski. Any photoshop book will have info too, but this one is only about Layers, nothing else. And it's not 7lb and 40 inches thick 40D, 5D3, a bunch of lenses and other things
| Latest registered member is semonsters 1463 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
