I've seen RRS's $50 gadget with a bunch of bits for hex, Torq and Phillips screws, but is there a cheaper or better one out there?
Thanks.
tvphotog Cream of the Crop More info | Sep 08, 2013 13:33 | #1 I've seen RRS's $50 gadget with a bunch of bits for hex, Torq and Phillips screws, but is there a cheaper or better one out there? Jay
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Sep 08, 2013 13:39 | #2 simply Google... 'tool hex Torq Phillips', and you find things like this You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Cheap tools can be a real PIA. I've got the RRS toolkit, so far it has worked great the couple of times I've needed to use it like installing a Lcf-10p on a nikon lens. Tiny screws that were very tight.
Sep 09, 2013 21:03 | #4 rick_reno wrote in post #16283277 Cheap tools can be a real PIA. I've got the RRS toolkit, so far it has worked great the couple of times I've needed to use it like installing a Lcf-10p on a nikon lens. Tiny screws that were very tight. I'm with you on value for money and I really like the compactness of the RRS tool. But I have a series 3 Gitzo and I wonder if the hex heads will be useful for what I suspect are metric bolts. Jay
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Sep 09, 2013 21:09 | #5 Haven't had a whole lot of need for Torx drivers. The Victorinox Swiss Army Cybertool 34 has several sizes of Phillips, Torx and hex drivers as well as flat blade drivers. Meets my needs unless on a cruise (where, since obviously a knife-wielding nut-case can hijack the ship and ram a critical governmental/organizational structure, with major loss of life and disruption to operations, a 3.2" blade must be confiscated) where I don't have it available. Jon
Sep 09, 2013 21:23 | #6 tvphotog wrote in post #16283420 But I have a series 3 Gitzo and I wonder if the hex heads will be useful for what I suspect are metric bolts. If you're talking about the leg joint screws on a 3-series that's a Torx T25 driver for the head and the thread on the screw part is metric 6 (M6). ~Peter
Sep 10, 2013 05:44 | #7 Jon wrote in post #16283437 unless on a cruise (where, since obviously a knife-wielding nut-case can hijack the ship and ram a critical governmental/organizational structure, with major loss of life and disruption to operations, a 3.2" blade must be confiscated You jest! What do they make you use to eat your food - rubber knives? World gone mad Frank Hollis - Retired mass spectroscopist
drvnbysound Goldmember 3,316 posts Likes: 12 Joined Aug 2009 More info | Sep 10, 2013 06:34 | #8 Would this help? I use manual exposure settings on the copy machine
Sep 10, 2013 07:08 | #9 drvnbysound wrote in post #16284239 Would this help? http://digital.hammacher.com …74670/74670_1000x1000.jpg No good - it hasn't got one of them tools for removing boy scouts from horse's hooves. Frank Hollis - Retired mass spectroscopist
John333 Member 85 posts Likes: 1 Joined Sep 2011 More info | Sep 10, 2013 09:09 | #10 not cheaper (unless you can find a sale), but excellent quality
Sep 10, 2013 11:09 | #11 ^ +1. Leatherman is good. I like the Mako Ti ~Peter
monty87 Senior Member 306 posts Likes: 121 Joined Feb 2008 Location: So Cal High Desert More info | Sep 10, 2013 12:29 | #13 I just picked up the Kobalt 9-Piece Folding Flat End Hex Key Set from lowes for like 6 bucks. So far no issues with it. works as intended. Monty - http://umang.photography/
| Latest registered member is semonsters 1014 guests, 106 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
