Thread started 10 Sep 2013 (Tuesday) 16:21
This is driving me bonkers!!!
RandMan
Joined Mar 2012
Sep 10, 2013 16:21 |  #1
Delete everything. Make small tweak. Run action. Delete everything. Make small tweak. Run action. Delete everything. Make small tweak. Run action.
Alright, so I have all the "guts" written for my action and it plays out smoothly and with no legitimate speedbumps. Two cosmetic things, however, have got me absolutely stumped.
    I have color-coded some of the layers to visually categorize them quickly
    When I consolidate all the layers and groups to one main/master group at the end of the action, all the organizational colors for the layers disappear
    The good news is that when you replay the action it leaves you with one group that holds everything, and it's COLLAPSED nice and tidy
    If I do the above in reverse, and create the master group and then apply the color coding, then I get an action that replays with all the nice colors in place, but leaves me with a fully EXPANDED stack of groups and layers
I have just done about 15 or 20 retakes, trying every tweak I can think of. How can I end up with a collapsed group that contains all the colored layers? This is an exercise in absolute insanity!
Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
D ­ Thompson
Sep 10, 2013 17:12 |  #2
Sorry, I don't have time till later to try something, but would this work?
Create a new action.
Start recording action.
Run the action that has the layers color coded but expanded.
Close the group.
Stop recording action.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
RandMan
Joined Mar 2012
Sep 10, 2013 17:48 |  #3
D Thompson wrote in post #16285985 (external link)
Close the group.
I'll try it in a few minutes after I return to the computer - I had to walk away and see what reality looks like for a moment. I am skeptical, though, because Photoshop cannot register collapsing and expanding groups; I even tried right-clicking earlier on the little group triangle and clicking its own "collapse group" command. Err! I'll let you know the results momentarily.
RandMan
Joined Mar 2012
Sep 10, 2013 18:05 |  #4
RandMan wrote in post #16286059 (external link)
No Dice.
D ­ Thompson
Sep 11, 2013 09:13 |  #5
Can you explain a little further what you're trying to accomplish with the action? If I'm understanding you are color coding some layers, putting them into groups, then putting all the groups into a "master" group and collapsing all so that all you see is the background layer and the "master" group. Are you manually color coding the layers?
Dennis
kirkt
Sep 11, 2013 09:42 |  #6
Weird - I tried a simple exercise - opened an image. Start recording action...
make a curves adj layer - make an adjustment - right-click and color code the adj layer red
make an exposure adj layer - make adjustment - right-click and color code the adj layer green
select both adj layers - make new group from layers - in dialog, rename group and color code it blue - hit OK.
Stop action.
this produces a group, coded blue, that is collapsed - it has a red coded and green coded adj layer in it.
I assume this is an example of what you are trying to achieve, but the color coding is somhow getting stripped or changed?
It worked for me in CS6 and CC. PM me if you want to email me your action - I'll see if I can track down what is not working, or at least test it in my PS.
kirk
kirk
Kirk
RandMan
Joined Mar 2012
Sep 11, 2013 10:58 |  #7
D Thompson wrote in post #16287720 (external link)
kirkt wrote in post #16287805 (external link)
Stop action.
kirk
kirk
If you want, I can email both of you the action. I think I still have two versions so I can send both - one that collapses nice and tidy but loses the colors, and the other that keeps all the colors but stays expanded. In the meantime, basically it's a portrait retouching action; the main group is only to hold everything in one layer, then there is a subgroup for teeth, then a subgroup for eyes, and a subgroup within the eyes subgroup for the irises. There's really not a whole heck of a lot to it.
Kirk - did you try replaying your action after you created it? Reason I ask is that mine would be perfect from hitting the record button through stopping it. But when I would play it back just to verify it before saving, then things were different.
kirkt
Sep 11, 2013 11:32 |  #8
yes I replayed it and it worked. I did not try making sub-groups though.
kirk
Kirk
D ­ Thompson
Sep 14, 2013 11:17 as a reply to  @ kirkt's post |  #9
I can’t get it to work either in the actions you sent. I wonder if it could be done using a script, but I know nothing about creating scripts so no help there. You might post this over on the Adobe forum and see if someone there might have any suggestions.
In the meantime, there is a very simple way to collapse all the groups, but doesn’t work in the action. Hold the Ctrl & Alt key, then click on the triangle on the top level group (Freq Sep in this case). It will collapse all the subgroups as well. If they are collapsed then it will expand them all.
Dennis
René ­ Damkot
Sep 20, 2013 13:45 |  #10
How are you creating the groups? There are some inconsistencies in that, as we discussed here:
https://photography-on-the.net …p?p=15986050#po​st15986050
Might have something to do with it? Never tested.
Also: In PSCS6, if you color code a group, that will color code all layers inside it with the same color.
The exception is upon creation of the group; if you select a bunch of layers, then Shift+Alt click the "New group" Icon, only previously un-color coded layers get the selected color…
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
RandMan
Joined Mar 2012
Sep 23, 2013 20:22 |  #11
René Damkot wrote in post #16312173 (external link)
Yup - I remember when you chimed in on that other thread of mine, and I'm aware of the other things you just mentioned. However, the mystery still lives on!
3,044 views & 0 likes for this thread, 4 members have posted to it.
1061 guests, 103 members online
