Thread started 13 Sep 2013 (Friday) 15:00
40d shutter too slow with flash
trailguy
Sep 13, 2013 15:00 |  #1
I've apparently changed a setting. In Av mode, with popup flash, indoors the flash fires and the shutter remains open several seconds, as if no flash.
Anyone know what setting I need to change?
Perfectionism is the highest form of self-abuse
"Best wide-angle lens? Two steps backward"
Ernst Hass 1952
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Sep 13, 2013 15:10 |  #2
In AV mode the camera tries to expose as if the flash were only there to provide fill. So its behaving normally. Indoors use M mode to control the shutter speed and aperture and let the flash bridge the gap between the 2 settings. I dont have my 40D handy, and I never used the Cfn setting but you can set a safety shift that sets a min shutter speed in AV mode thats faster (maybe 1/200) but its not really AV mode if your SS is fixed.
rral22
Sep 13, 2013 15:17 |  #3
As gonzo has indicated, AV mode is the problem. In AV mode your camera tries to expose the scene properly by extending the shutter time - as it should in any circumstances - so you get long exposures. I would set the camera to M mode; set the aperture to something like f5.6 so you have good depth of field; set the shutter to about 125th and the flash should expose everything properly. If it doesn't, use some flash compensation as required.
ejenner
Gallery: 98 photos
Joined Nov 2011
Sep 13, 2013 16:18 as a reply to  @ rral22's post |  #4
While I would also use M, the setting you need to change is in one of the flash options.
I don't have a 40D but there should be something like 'Shutter Speed with Flash":
1. AUTO
2. AUTO 1/60 - 1/200
3. FIXED 1/200
You have it on 1 when you possibly want it on 2 or 3.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
trailguy
Sep 13, 2013 18:12 |  #5
ejenner wrote in post #16294361 (external link)
1. AUTO
3. FIXED 1/200
Thank you! I knew it was there somewhere, for I have taken many low light flash shots with no problem. I set it on 'fixed' 1/250 and it works well on Av. If needed I can always go to M mode. I don't use automatic mode (just doesn't feel right).
Ernst Hass 1952
ejenner
Gallery: 98 photos
Joined Nov 2011
Sep 13, 2013 22:27 |  #6
trailguy wrote in post #16294574 (external link)
I actually got caught out in the other direction fairly recently - I couldn't figure out why I couldn't get a SS higher than 1/250 (or 1/200) with high speed sync in Av mode. But then I actually use flash more outside in fairly bright conditions with larger apertures than I use it indoors.
Since I use flash in bright conditions a lot I usually have this option set to auto and use M indoors instead. Of course use what works the easiest for you, just be aware that if you go outside with a large aperture you may get over-exposed shots if trying to use flash for fill, even if you try to use high speed sync.
Edward Jenner
1,163 views & 0 likes for this thread, 4 members have posted to it.
1228 guests, 149 members online
