Thread started 13 Sep 2013 (Friday) 23:30
Sometimes polarizers make a Huge difference
calypsob
Joined Jan 2012
Sep 13, 2013 23:30 |  #1
These shots were both taken within a few minutes of each other. The first shot has no polarizer filter and the second has a b+w Circular Polarizer E at full polarization, 90 degrees dialed away from the sun. The reason I wanted to share this is because I had always been curious about how much light it would remove and thought others may benefit as well. These images are straight raw from the camera and have had no post processing done to them. Both shots were taken at 300mm F10 iso100 first shot 1/40 a second shot the same only 1/10 of a second, so you loose 1/30 of a second using a circular polarizer. These are both shot in natural light no flash.
IMAGE: http://farm8.staticflickr.com/7431/9739671526_88492a9479_z.jpg
IMAGE LINK: http://www.flickr.com …/70374000@N08/9​739671526/  (external link)
unpolarized (external link) by LMNO Sunset Deluxe (external link), on Flickr
IMAGE: http://farm8.staticflickr.com/7420/9737465373_c09333e290_z.jpg
IMAGE LINK: http://www.flickr.com …/70374000@N08/9​737465373/  (external link)
IMAGE: http://farm8.staticflickr.com/7348/9739699636_a88d89d61e_z.jpg
IMAGE LINK: http://www.flickr.com …/70374000@N08/9​739699636/  (external link)
eye crop (external link) by LMNO Sunset Deluxe (external link), on Flickr
IMAGE: http://farm8.staticflickr.com/7408/9739699714_174362abd8_z.jpg
IMAGE LINK: http://www.flickr.com …/70374000@N08/9​739699714/  (external link)
eye crop polarized (external link) by LMNO Sunset Deluxe (external link), on Flickr
Wes
Gear: Many gears Yes.
LordV
Sep 14, 2013 00:51 |  #2
Good comparison. Does have a marked effect. Your shutter speed loss seems to correlate well with the 2 stop light loss I'd heard for polarisers.
Brian v.
Macro Hints and tips
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Sep 14, 2013 08:11 |  #3
Interesting comparison, yes you typically loose about 2 stops.
Probably worth using if shooting by traditional methods with a tripod and mirror lockup, if working handheld one probably can't afford the light loss.
Would be worth trying this with very metallic and reflective species like Demoiselles and some of the beetles.
Macrophotography by LordV
calypsob
Joined Jan 2012
Sep 14, 2013 11:10 |  #4
Lester Wareham wrote in post #16295687 (external link)
good point lester, in this instance I was not doing hand held because I was using a 300mm, which would be close to impossible to handhold. Im not sure how this would work with a flash though, I guess if you can stay at 1/200 and turn up the flash then it may work. Another option would be to use a higher iso to compensate shutter speed, I was shooting at 100.
Wes
mandokid1
Gallery: 718 photos
Joined Nov 2010
Sep 15, 2013 10:20 |  #5
nice comparison wes.
I use them for landscape,and often thought about using them for macro.
DENIS
Snowyman
Gallery: 682 photos
Joined Oct 2011
Sep 15, 2013 11:24 |  #6
I tried a Polarizer with flash once, the problem is getting the angle right. As far as I can tell you need to be a maths wizard, a clairvoyant, or an incredibly fortunate individual. :|
Snowy's Gear
Deviant Art (external link)
500px (external link)
BasAndrews
Gallery: 100 photos
Sep 15, 2013 11:41 |  #7
Great comparison Wes.
Bas (external link)
954 views & 0 likes for this thread, 6 members have posted to it.
1609 guests, 140 members online
