I have the 85mm, and just picked up a 100mm Macro Mk1. I've been wanting a good macro, and this will be easier to work with then my 60mm.
I use the 85mm as a portrait lens, and not much else. Now I'm starting to think I don't really need the 85mm anymore, as the 100mm should result in results that are similar to the 85mm.
Anyone with experience with both? Is one significantly better then the other in sharpness, color rendition, contrast? Or are they similar enough that I won't miss the 85mm?
I'm using these on a 50D, so I think the 100mm might be too long, but I'm not sure. I also have a Mk1 nifty fifty. Is having these 3 lenses overkill? Or is it a nice set of primes that give me good range? ie., is it worth it to keep the 85mm, or should I sell it? I do need to free up some change to replace my 10-20mm that is now in two pieces.
