Thread started 16 Sep 2013 (Monday) 20:21
Can you have lint inside the lens?
WC4Glam
Sep 16, 2013 20:21 |  #1
This may sound like entry level question but can a lint/hair get inside the lens?
I just noticed my 100mm macro lens show a hair-like object on the photo.
Upon close inspection, I can see it on the lower left corner. I tried to swipe and clean the outside but looking at the lens through my loupes I can see it is coming from the inside of the lens.
What should I do? Can this be clean out via a local shop or should I send it back to Canon for clean out. Btw, this lens been with me over 6-7years. I don't expect their is any warranty.
Much appreciate for your advise.
70D;50D; 18-135 STM, macro 100mm, 2.8; 35mm;Tamron 17-50mm, 2.8; canon 28-135mm; 580EX II, MR14EX
TJays
Joined Mar 2013
Sep 16, 2013 20:46 |  #2
Lint inside the lens can't think I have ever come across that. Are you sure it's not mold ? that will grow inside.
Regards
Terri Jean
5D4 Gripped-EOS 1DX Markll -600mm/4.0 II L-35-350mm/3.5 L-70-200/2.8 L-24-70mm/2.8 L-85mm/1.2 II L-50mm/1.2 L
ejenner
Gallery: 98 photos
Joined Nov 2011
Sep 16, 2013 21:38 as a reply to  @ TJays's post |  #3
JMO, send the lens to canon for cleaning. They will charge about $200 which isn't too bad IMO for a lens you've been using for 7 years.
FWIW, I noticed my 100mm L has quite a bit of dust in it, including some larger specks. Not enough to get worried, but I've only had it a year. So I suspect it is not as sealed as one might hope.
Personally I think almost anything can get into a lens, although I have no idea how it happens on lenses like the 100L, 135L or 70-200's that are basically sealed at both ends.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
chtgrubbs
Joined Jul 2003
Sep 16, 2013 21:45 |  #4
If you are seeing it in the photo it is most likely on your sensor, not in the lens.
ejenner
Gallery: 98 photos
Joined Nov 2011
Sep 16, 2013 21:47 |  #5
chtgrubbs wrote in post #16302453 (external link)
That's what I was thinking at first, but with a macro at close distances and stopped down, you can see larger chunks of stuff on the lens where you wouldn't on a non-macro.
OTOH checking the sensor with another lens would seem prudent.
Edward Jenner
DreDaze
Gallery: 49 photos
Sep 16, 2013 22:02 |  #6
i'm sure you can get some lint in a lens...but it's doubtful that it will affect your photos...so the best solution is to not look inside your lenses
Andre or Dre
gear list
Instagram (external link)
paintedlotus
Sep 16, 2013 22:21 as a reply to  @ DreDaze's post |  #7
I'm reasonably sure that lint could somehow get in the lens, if that is actually what is happening... my basis for this belief is that I had a small bug crawling around inside my old 50 1.8 until it (the bug) died. Its husk is theoretically rattling around inside the damn thing to this day (that was maybe 3 or 4 years ago that I noticed it). It's no longer within the field of vision of the lens though. I am not making this up. :)
Website (external link)
beauty, fashion, model tests, portraits
WC4Glam
Sep 16, 2013 23:15 |  #8
I left the camera and the lens at the office. I'm concern of it because I can see it on the photo, I will also verify the sensor with my recent purchase of 35mm. Thanks for all the tips so far
richardberggs
Joined Sep 2013
Sep 17, 2013 07:20 |  #9
WC4Glam wrote in post #16302660 (external link)
Mate i to have a same like issue, a thin hairy line appears on the pictures when i use the cam full zoom
BacklinksVault (external link)
DreDaze
Gallery: 49 photos
Sep 17, 2013 09:30 |  #10
if you can see it on pics, i think it's most likely something on your sensor...
Andre or Dre
gear list
2,003 views & 0 likes for this thread, 7 members have posted to it.
1439 guests, 128 members online
