Thread started 17 Sep 2013 (Tuesday) 14:53
Yikes! Help! What's going on with my 5D mk3?
Whippeticious
Sep 17, 2013 14:53 |  #1
I always download my photos by plugging in my camera, I've done it like this for years without a problem. This morning I first downloaded off the 7D and then plugged the 5D in and it did nothing. I unplugged it and tried to turn it on and it wont. Then I noticed the red light on the lower right hand side flashing even though the actual camera was turned off.
I've removed the battery for now and thought I'd ask here if anyone knows what's going on with it.
WaltA
Gallery: 10 photos
Joined Feb 2006
Sep 17, 2013 14:55 |  #2
Whippeticious wrote in post #16304384 (external link)
Sounds like its having a problem writing to the card.
You might want to take it out and check for pin problems.
Walt
400D, 5D, 7D and a bag of stuff
Whippeticious
Sep 17, 2013 14:57 |  #3
I haven't removed the card since I first put it in at purchase about 18 months ago. I dont understand why it would have pin problems.
WaltA
Gallery: 10 photos
Joined Feb 2006
Sep 17, 2013 15:01 |  #4
Whippeticious wrote in post #16304400 (external link)
Or maybe it needs to be formatted? Or it got jarred loose?
The flashing red light indicates writing to the card (unless that model has other uses for that light than I'm familiar with).
Walt
Whippeticious
Sep 17, 2013 15:06 |  #5
Hmmmmm I've put the battery back in and once again the red light started flashing even though the camera was turned off. I tried switching it back on and the red light flashed a couple more times but the camera remains deady bones. Nothing............... :(
travisvwright
Gallery: 21 photos
Joined Feb 2013
Sep 17, 2013 15:11 |  #6
Have you removed the card yet?
I come here for your expert opinion. Please do not hesitate to critique or edit.
70D, 6D, Canon 135, Tamron 28-75 2.8, Tamron 70-200 2.8 VC, Canon 50 1.4, Canon 100 2.8 Macro, Canon 85 1.8, Canon 10-18 4.5 STM
Franklin NC Photographer Travis Wright (external link)
Whippeticious
Sep 17, 2013 15:11 |  #7
Yep, just tried that, took it out, put it back, still nothing.
WaltA
Gallery: 10 photos
Joined Feb 2006
Sep 17, 2013 15:13 as a reply to  @ WaltA's post |  #8
WaltA wrote:
=WaltA;Or maybe it needs to be formatted Or it got jarred loose?
My other suggestion was that it needs to be formatted.
Walt
Whippeticious
Sep 17, 2013 15:16 |  #9
but if I formatted the card wouldn't I lose all the photos that are on there? Also, I cannot do anything right now if the camera wont turn on, and that's the problem I'm having at the moment. :(
TJays
Joined Mar 2013
Sep 17, 2013 15:19 |  #10
if the camera won't turn on, remove the lens and see if it will turn on. Is the lens a large telephoto ?
Regards
Terri Jean
5D4 Gripped-EOS 1DX Markll -600mm/4.0 II L-35-350mm/3.5 L-70-200/2.8 L-24-70mm/2.8 L-85mm/1.2 II L-50mm/1.2 L
HiepBuiPhotography
Joined Mar 2012
Sep 17, 2013 15:20 |  #11
I'm gonna go out on a limb here and suggest that maybe your battery is dead? Charge it a little bit and try again.
Hiep Bui Photography | Harrisburg Wedding Photographer (external link)
Whippeticious
Sep 17, 2013 15:20 |  #12
aaah! I've just tried swapping the 7D battery into this camera and it turns on! Phew! so it seems there's a problem with the battery. Strange, I recharged it yesterday and it seemed fine. For now I'm just relieved the camera's working.
Motor ­ On
Sep 17, 2013 15:22 |  #13
The red light may just indicate, busy, which would be signal in/out of the usb. It may even say busy if you look through the viewfinder and try to get the camera to do something else.
Have you rebooted the computer? It sounds like fast switching of the camera has tripped up the computers recognizing the device was changed. If it still doesn't work on reboot then I'd download or get out the disk for the Canon software and reinstall the drivers.
Before you format the card I'd make the effort to try and download the images from the camera via a card reader (which you will likely find to be much much faster than plugging the camera into the PC).
Also if you can put the battery in the camera hit the play button and view the photos, then they likely aren't corrupt.
You can format a card and generally with special software recover the lost data so long as you do not write over the deleted information.
Website (external link) | Facebook (external link) | Instagram (external link)
WaltA
Gallery: 10 photos
Joined Feb 2006
Sep 17, 2013 15:23 |  #14
Whippeticious wrote in post #16304488 (external link)
Good to hear.
Walt
Whippeticious
Sep 17, 2013 15:34 |  #15
HiepBuiPhotography wrote in post #16304487 (external link)
You were writing at the same time as I discovered the problem. I fully charged that battery yesterday afternoon, after I'd taken all the photos as I noticed it was getting low. When batteries die, is it usually completely sudden like this seems to have done?
6,334 views & 0 likes for this thread, 10 members have posted to it.
887 guests, 133 members online
