dodgyexposure wrote in post #16305174
I'm looking at options for trekking with a DSLR. Currently, I attach a toploader bag to the shoulder straps of my backpack with Op/Tech uniloop connectors. I find this to be versatile, as I can disconnect the bag and use it with a normal strap if I just want to take the small bag. It also protects the camera from unexpected impacts and weather. A disadvantage is that the bag can obscure the view of my feet when walking/climbing.
Another option is to attach a Capture clip to a backpack strap. This would remove the visual obstacle from being in a direct line with my feet, and leave the camera more quickly accessible. The camera would, of course, be less protected.
I'm interested to hear from others who have tried this. In particular, is the connection of the clip to the strap difficult? I have read that the thickness of a backpack strap can be a problem with the attachment mechanism on the capture clip.
I can only be of some help as I have not used the capture clip system, but I have a DIY system that I made at work on our 3D printer, that uses the quick connect plate for my tripod (its a sunpak tripod from Costco), I did not want to have to change plates while out and about.
What I can help with is opinions on hanging from the backpack strap. After a full day of hiking you will feel lop sided when you remove the camera, while in Glacier National Park this summer I had days I used one combo and days I would carry two combos, although 2 was heavier at the end of the day when I removed my pack and gear I felt better. It is very nice for quick access however having it exposed is also a pain if your going through dens foliage.
There were many times I took the camera/s off my pack and stored them inside when I new I just needed to huff it to the top or bottom of the trail.
I plan to pick up a top loader to try out soon, as I think I will like the added protection, but I am also worried about the view impediment that comes with that set up.
