ArenGh wrote:
I understand what you've done here, but why is it standard to remove color cast? Sometimes, like this case, I think it gives it an artistic touch.
Correct me if I'm wrong though, I'm just a photography newb
It was precisely because you said you were a newbie that I thought I would post a modified image with the cast removed just in case you hadn't appreciated the cast.
I also agree however that a colour cast can give an artistic feel, but the trick is to make it obvious (and I've no definitive suggestion here) that this is what was intended rather than just being a white balance artefact.
