Thread started 20 Sep 2013 (Friday) 10:30
Lightroom (5) 'detail' panel settings
Christopher ­ Steven ­ b
Sep 20, 2013 10:30 |  #1
So I have finally given in and upgraded to Lightroom 5 to at least attempt to start using it to process my weddings / non-wedding stuff.
Looking at the defaults for LR5 in the detail panel especially, I note that I've been using dramatically different settings for sharpening.
I've been using approximately the following:
Amount: 70
Radius: .7
Detail: 7
Masking: 50 and up (ISO dependent)
I feel like these settings have been working for me but that it's time to re-evaluate them. What settings do you use in general ?
I should add: I shoot with a canon 5d classic.
christopher steven b. - Ottawa Wedding Photographer
www.christopherstevenb​.com (external link)| Blog (external link)
jefzor
Joined Jul 2013
Sep 20, 2013 10:46 |  #2
On a 600D:
In LR4:
Amount: 80
Radius: 1
Detail: 25 (should probably experiment more with this one)
Masking: 30-50, depending on the picture.
For soft or extremely high ISO photo's, I usually increase the radius to 2 or 3.
www.jefpauwels.be (external link)
Sep 20, 2013 10:56 |  #3
^Thanks a lot. Yours is fairly similar to mine--in stark contrast to the built-in defaults which seems to suggest low 'amount' and high 'detail' settings.
BigAl007
Gallery: 556 photos
Sep 20, 2013 10:56 |  #4
I shoot mainly Aviation subjects and with older cameras (300D 20D). I tend to use 60 on the amount, Radius and Detail stay at the default 1.0 and 25, and then anything between about 80 and 100 for the masking. Occasionally I might push the amount up to 70 or so and maybe the radius will go to 1.5 or very rarely 2.0. In those cases though the masking will very often end up at or above 90.
Alan
tonylong
...winded
Gallery: 60 photos
Sep 20, 2013 14:23 |  #5
I tend to go "light" -- I set the Amount to about 40 and only use Masking and/or Noise Reduction at higher ISOs (I also use the 5DC as well as my trusty ol' 30D).
I'm using LR4, but that should be similar to LR5. With LR3 and earlier, I'd typically use higher settings.
Tony
René ­ Damkot
Sep 20, 2013 14:58 |  #6
Christopher Steven b wrote in post #16311655 (external link)
Similar, using a 1D3 at "lower" ISO's (800 and up)
https://photography-on-the.net …showthread.php?​p=15422911
Oh, hit Alt, while adjusting the slider. Gives a more useable preview.
http://lightroom-news.com …oom-11-update/sharpening/ (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
tzalman
Fatal attraction.
Sep 20, 2013 16:56 |  #7
70/0.7/15/30
On landscapes Detail 70-80.
For high ISO Detail 10, Mask 60-70.
Elie / אלי
MikeBurtonPhillipson
Gallery: 6 photos
Sep 20, 2013 17:12 |  #8
Rene beat me to it... i was just going to say don't forget to use Alt when using the sliders (works especially well for me when applying masking)..
5DmkIII | 7D | 24-105 f4L IS | 70-200 f2.8L II IS | 100-400 f4.5-5.6L IS | 100mm F2.8 Macro | 15-85 IS | 400D | Tokina 10-17 fisheye | 400D Ikelite Underwater housing |
http://www.mikeburtonp​hillipson.co.uk (external link)
Bianchi
Gallery: 41 photos
Sep 21, 2013 01:32 |  #9
[QUOTE=MikeBurtonPhill​ipson;16312596]Rene beat me to it... i was just going to say don't forget to use Alt when , when you hold alt
Yep, for those that don't know how it exactally works, holding the alt key while sliding the mask slider, everything white gets sharpened, and everything black doesn't....
RandMan
Joined Mar 2012
Sep 23, 2013 19:53 |  #10
I usually do:
Amount - 50
Radius - .8
Detail - 10 for soft images/50 for high detail
Masking - 70 for soft images/30 for high detail
Remember that RAW sharpening is only input sharpening, and it's geared differently than Photoshop because of that exact reason (for example, compare the same radius and amount values on the same image in Photoshop and Lightroom - in Photoshop the effect will be much more pronounced because it's tuned for output sharpening). All you're trying to accomplish is to take the natural softness off the image that happens during the transformation in camera from light to a picture.
Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
-MountainDog-
Gallery: 15 photos
Sep 24, 2013 14:31 |  #11
Typical for landscapes of mine:
Amount: 45
Radius: .8
Detail: 25 (default- Haven't experiment much with this effect)
Masking: 50ish (usually increase mask until the sky doesn't get sharpened)
Looks like I might be on the lighter side of "amount". I'll have to play with higher numbers.
Canon 70D; 18-135 IS STM, 15-85mm IS, 55-250mm IS, 35mm f2 IS, 50mm 1.8 II, Opteka 6.5mm Fisheye, 430ex II, YN-568ex II, Manfrotto 190CX3 w/ 496RC2, Olympus OM-4, 27" i7 iMac, Lightroom 5
4,015 views & 0 likes for this thread, 10 members have posted to it.
1686 guests, 141 members online
