Thread started 21 Sep 2013 (Saturday) 22:19
E-TTL and softbox
chenga732
Sep 21, 2013 22:19 |  #1
Hi,
I am just starting to learn about the lights and the different mode. With a speedlite and a softbox, you can set it to manual mode. Can E-TTL still work if the speedlite is inside a softbox? I have seen many people use E-TTL without a softbox.
Xsi|24-105mm f4.0|70-200mm f4.0|85mm f.18
dmward
Gallery: 29 photos
Sep 22, 2013 00:44 |  #2
I commonly use ETTL with the speedlite in a soft box.
The TTL metering reflective from the subject so the fact that the speedlite is inside a modifier is irrelevant.
Tiberius
Sep 22, 2013 01:08 |  #3
^^^That.
ETTL works by the camera analysing the amount of light that falls on the subject. It's doesn't think about the light in terms of how much each individual flash is outputting.
My photography website!PHOCAL PHOTOGRAPHY (external link)
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Sep 22, 2013 03:03 |  #4
Tiberius wrote in post #16315389 (external link)
The camera works by analysing the light that is reflected by the subject and enters through the lens.
It is why there can be a difference between a light meter measuring the beam of light that could hit the subject and be totally reflected to the camera, and what the camera says. The camera is more accurate.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
Tiberius
Sep 22, 2013 04:28 |  #5
CliveyBoy wrote in post #16315534 (external link)
Gah, that's what I meant.
I meant that it works by measuring the light it sees hitting the subject and reflecting off into the camera, rather than figuring, "The flash is X feet away from the subject, so it has to fire at a strength of Y in order to expose properly."
drvnbysound
Sep 22, 2013 08:25 |  #6
Are you saying ETTL metering from a camera is more accurate than a light meter? :confused:
I use manual exposure settings on the copy machine
..::Gear Listing::.. --==Feedback==--
...A few umbrella brackets I own...
drvnbysound
Sep 22, 2013 08:26 |  #7
Tiberius wrote in post #16315609 (external link)
The flash has no idea how far it is away from you or your subject.
chenga732
Sep 22, 2013 13:49 |  #8
Thanks everyone for their inputs. How much light is lost thru the softbox?
GooseberryVisuals
Joined Nov 2010
Sep 22, 2013 14:02 |  #9
chenga732 wrote in post #16316548 (external link)
How long is a piece of rope?
CliveyBoy
Joined Nov 2005
Sep 22, 2013 18:57 |  #10
drvnbysound wrote in post #16315879 (external link)
Yes, I am, despite old hands' expertise in using meters.
By more accurate, I mean that the camera reads the light which actually comes through the lens onto the sensor. The light meter is way back in the chain, and fails to measure how much of the incoming light is going to be reflected into the lens, the reflectivity and reflection angles of the subject. For example, a light may be putting a thin slice of high output onto a dark-skinned side of the face, with the side at 50 degrees to the camera.
The camera takes the actuality into account; the light meter measures just the emitted light. The meter needs more interpreting than the camera sensor.
Tiberius
Sep 22, 2013 19:02 |  #11
drvnbysound wrote in post #16315890 (external link)
Which is why I said the flash/camera doesn't work that way. :)
drvnbysound
Sep 22, 2013 20:58 |  #12
CliveyBoy wrote in post #16317072 (external link)
Ehh, I've used ETTL... I've wouldn't call it 'accurate'
However, when I use my flash meter with manual flashes, I can put any subject I want in front of the camera and get a proper exposure without changing anything.
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Sep 23, 2013 12:05 |  #13
I would not call it accurate either. Very close but not on the money. If I'm shooting at that level the flash goes on manual and out comes my L-358.
Image Editing OK
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Sep 23, 2013 12:23 |  #14
ETTL is great for situations where there is a great deal of variety in the lighthing and working distance from shot to shot, but for studio use manual and a light meter is preferable. If for no other reason that ETTL meters each shot independently so you could have the same two subjects but two different exposures because of a minor change in position.
drvnbysound
Sep 23, 2013 12:40 |  #15
gonzogolf wrote in post #16318735 (external link)
That is the lack of accuracy that I was referring to.
If I'm setting up a softbox, chances are I'm not in an environment or shooting where the lighting is changing enough to use ETTL.
9,562 views & 0 likes for this thread, 10 members have posted to it.
E-TTL and softbox
1505 guests, 137 members online
