Thread started 22 Sep 2013 (Sunday) 00:25
easiest method to get 360deg virtual tour using 5d/5d2 with 17-40L and normal tripod?
the.forumer
Joined Oct 2011
Sep 22, 2013 00:25 |  #1
as above - i've been reading up on how to make 360degree virtual tours (interior use), but so far most of them only teach using a pano head and fisheye.
i'd like to avoid distortion, hence my choice for the 17-40L. how can i achieve that with a normal tripod and ballhead?
links to videos would be most helpful. thanks!
Nightstalker
Sep 22, 2013 05:39 |  #2
It depends on the quality of the result that you want.
The pano head ensures that you revolve around the nodal point of the lens - a normal head will not but the level of distortion you introduce sould be manaheable.
As for doing - ensure that everything is level and shoot with the camera in portrait enxuring that you get plenty of overlap on the images.
At 17mm you get a 70 degree horizontal field of view (with the camera in portrait) so I would be looking to shoot a 360 in 8 steps.
AT 40mm you get closer to 35 degree so would be looking at around 16-18 images. Rotate the camera through 20 degrees per shot gives you 18 shots.
Try to make sure that the images are equally spaced
Smitty2k1
Gallery: 22 photos
Joined Mar 2012
Sep 22, 2013 09:16 |  #3
the.forumer wrote in post #16315327 (external link)
You're REALLY going to want a pano head and fisheye
kirkt
Sep 22, 2013 09:31 |  #4
Here is a pano calculator to help you sort out FOV and image overlap, etc.:
http://www.hdrlabs.com​/tools/panocalc.html (external link)
Using a standard pan move on a tripod will work okay (in terms of parallax) if your image plane if far away (like a landscape). For interiors, parallax errors get difficult to overcome very quickly as objects closer to the camera shift compared the background as you pan the camera around the tripod mount. You may have some luck in combating this by using Smartblend, a blending algorithm that attempts to account for parallax errors.
http://wiki.panotools.​org/SmartBlend (external link)
If you are going to shoot these kind of interior spherical panoramas, you will do yourself a big favor by investing in a dedicated pano head - even a relatively inexpensive one will give you the ability to locate and pan around the no parallax point (NPP) of your particular optical system.
Here is a nice write up about finding the NPP:
http://www.johnhpanos.​com/epcalib.htm (external link)
and here is some more basic information about the concept:
http://wiki.panotools.​org/No-parallax_point (external link)
This is really important because as you shoot a lot of image sets to stitch, if your set up is meticulous and repeatable, automation of the stitching process gets more and more efficient and saves you time and money.
good luck!
kirk
Kirk
kirkt
Sep 22, 2013 09:37 |  #5
Here is an old thread I started with some images of the set up I use with a 5D and 5DII.
https://photography-on-the.net …045813&highligh​t=panorama
kirk
Kirk
Lowner
"I'm the original idiot"
Sep 24, 2013 10:46 |  #6
Smitty2k1 wrote in post #16316018 (external link)
Its a good trick if you can avoid distortion with a fisheye!
Richard
whitesell
Sep 24, 2013 11:04 as a reply to  @ Lowner's post |  #7
The software used to stitch the images shot with fisheye lenses take the distortion out of the final 360-degree spherical image. Check out panotour from kolor.com to see examples.
http://www.kolor.com …rtual-tours-360-home.html (external link)
Regards,
Jim Whitesell
Edmonton portrait photographer (external link)
Google Business Photos Edmonton (external link)
Gear list
1,471 views & 0 likes for this thread, 6 members have posted to it.
1501 guests, 134 members online
