Thread started 22 Sep 2013 (Sunday) 09:28
issue with Lexar Professional SD+CF USB3 card reader
the.forumer
Joined Oct 2011
Sep 22, 2013 09:28 |  #1
saw a lot of good reviews on this card reader and bought this for my desktop.
there's a very silly issue now - the card reader stays connected to my desktop all the time. however, when i connect a sd card to it, there's no response unless u unplug and plug in the usb3 cable again.
anyone else experience the same issue as well? is there a way to make the reader stay active 24/7 when the desktop is on?
thanks!
turboturtle
Joined Jan 2005
Sep 23, 2013 01:01 |  #2
Try updating the firmware. Fixed mine when I was having issues.
the.forumer
Joined Oct 2011
Sep 23, 2013 09:40 |  #3
turboturtle wrote in post #16317648 (external link)
did u mean the card reader firmware or?
not that i'm aware of, even after searching for it :
www.lexar.com/products​/lexar-professional-usb-30-dual-slot-reader (external link)
DisrupTer911
Sep 23, 2013 10:09 |  #4
What kind of laptop/desktop is it?
OS?
hardware?
Have you tried it in a USB2.0 and left plugged in 24/7 and tested?
Does it happen only after you read a CF card or do you only read SD cards?
Does it happen during card swaps when importing?
www.vividemotionphotograph​y.comexternal link
Bearmann
Location: I live behind Graceland in a tool shed. I often meet the man early in the morning at Krispy Kreme.
Sep 23, 2013 10:49 |  #5
My older compact flash reader does something similar, which I presume is the same issue on my windows machine. If I boot the computer without a card in the external card reader slot, it loses the connection. As long as I leave a card in the slot at all times, the connection stays on. If I reboot the computer with a card in the slot, it reconnects. I never tried unplugging and replugging the USB wire. Just leave a card in the reader at all times, and switch the card as needed- see if that works.
Barry
http://b-r-s-photo.zenfolio.com (external link) (remove the dashes)
the_weird_one
Sep 23, 2013 16:45 |  #6
Could be an issue with the USB3 driver as well, my system needed a driver update before it saw my internal card reader, then it was intermittent and a third usb driver and its stable and faster than my Lexar reader
| Canon EOS 7D + Battery Grip | Canon Speedlite 430EX II | Canon 24-105 f4L IS USM | Canon 100mm f2.8L Macro IS USM | Canon EF 50mm f1.8 | Sigma 10-20mm f/4-5.6 EX DC HSM | Sigma 70-200 f2.8 APO EX DG OS | Tamron SP 24-70 f2.8 Di VC USD |
My Flickr (external link)
the.forumer
Joined Oct 2011
Sep 23, 2013 18:27 |  #7
Bearmann wrote in post #16318488 (external link)
that's the same issue i have, but i don't want to leave a card inside as a workaround, cos it'd shorten the lifespan of the card and the reader over time (i guess)?
usb3 drivers 'can't be updated' because i'm on win8 and the native drivers come straight from win update. it's already the latest.
the.forumer
Joined Oct 2011
Sep 23, 2013 18:28 |  #8
DisrupTer911 wrote in post #16318388 (external link)
OS?
hardware?
it happens no matter whether it's CF or SD card. usb2 port is also the same.
no it doesn't happen during card swaps.
hollis_f
Sep 24, 2013 03:30 |  #9
the.forumer wrote in post #16318310 (external link)
Did you click on the bit that says 'Downloads' on that page?
If the latest firmware doesn't fix your problem then You might try the bit that says 'Support'
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
Bearmann
Sep 24, 2013 08:31 |  #10
the.forumer wrote in post #16319589 (external link)
No, I wouldn't think so.
Barry
John ­ from ­ PA
Joined May 2003
Sep 24, 2013 15:22 |  #11
Select applicable firmware update at http://www.lexar.com/d​ownloads (external link)
the.forumer
Joined Oct 2011
Sep 25, 2013 06:56 |  #12
John from PA wrote in post #16322127 (external link)
i'm using win 8 x64, so there's no download available for me..
NinetyEight
"Banned for life"
Sep 28, 2013 07:45 |  #13
the.forumer wrote in post #16323803 (external link)
You'll probably find the Win7 driver is fine, some companies fail to update the text on their download pages.
If in doubt contact Lexar support.
It is updating the card reader firmware not the PC driver as far as I know. I seem to remember having to do this to enable UDMA mode or something(??)
EDIT: if you do update it, I had to plug it into a USB2 port to update:
instructions for installing the LX01 Firmware Upgrade.
1: Before you begin, please make sure that the card reader is connected to your computer and all memory cards are removed from it.
2: Next, click the “Lexar Professional USB 3.0 Card Reader …Update Tool V1.0.0” file. This will launch the Firmware Update Tool.
3: The tool will display your reader’s current firmware version and the new firmware upgrade version (LX01). Please click the “Start” button.
4: When prompted “Are you sure you want to update…”click the “OK” button.
5: This process may take several minutes. Please do not disconnect the reader or turn off your computer during the update process.
6: Once the firmware update is done, the program will display the message: “FW Update Successful!” Click the “OK” button.
7: The “Firmware Update” dialog box should now display “LX01” as the current firmware for your reader. Click the “Done” button.
NOTE: PLUG UNIT INTO USB2 PORT
Kev
klr.b
Sep 28, 2013 16:32 |  #14
Are you choosing "safely remove hardware" before removing the card? That's essentially unmounting the drive from your computer. When you plug the USB cable back in, the computer mounts the card and reader as a drive again.
gordon
Gear and Feedback
6,310 views & 0 likes for this thread, 9 members have posted to it.
1501 guests, 134 members online
