Thread started 22 Sep 2013 (Sunday) 19:06
Transmitter Gear Question!
Drrobinson
Joined Jan 2013
Sep 22, 2013 19:06 |  #1
If i have 2 550Ex, do I need a transmitter & receiver or will the 550ex master and slave act as a wireless transmitter and receiver?
So, do I need a st-e2 or radiopoppers or pocket wizards if I have these two flashes?
P.S. I shoot weddings so a long wire is out of the question. What do you suggest?
Charlotte NC, Wedding Photographers
Anchor & Veil Photography (external link)
Facebook (external link)
"My Anchor holds within the Veil"
oldvultureface
Gallery: 85 photos
Sep 22, 2013 19:25 |  #2
Drrobinson wrote in post #16317093 (external link)
... will the 550ex master and slave act as a wireless transmitter and receiver?
Within the limitations (line of sight, distance) of the optical system, yes.
Drrobinson
Joined Jan 2013
Sep 24, 2013 12:57 |  #3
So should i get receivers?
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Sep 24, 2013 13:05 |  #4
Drrobinson wrote in post #16321710 (external link)
For weddings certainly. You cant have the vagaries of line of sight be an issue. You need reliable communications between the camera and the flashes.
ksbal
Gallery: 374 photos
Best ofs: 9
Sep 24, 2013 16:45 |  #5
I suggest YN-622's, or pocket wizards. An st-e2 will still have line of sight problems.
Godox/Flashpoint r2 system, plus some canon stuff.
apersson850
Gallery: 35 photos
Sep 25, 2013 20:16 as a reply to  @ ksbal's post |  #6
A few years ago, I had three 580 EX II flashes. They do work, with one as the master and the other two as slaves, but it's 100% correct that you have to move them around and test different locations for the flashes to make them work each time. That's fine for dead subjects. Fortunately, people getting married are rarely dead.
Now I use an ST-E3-RT master with up to four 600 EX-RT flashes. The radio control is most certainly quite a bit more reliable than the old optical system. It also works just as well in strong ambient light.
Canon's radio system is of course expensive, but it still shows the advantage of radio over visible light in this case.
Anders
elv
Sep 26, 2013 09:28 as a reply to  @ apersson850's post |  #7
If you have a look through the "Coming Soon" products in the right side bar here -
http://flashhavoc.com/ (external link)
you can see the first 7 of 9 product coming are all related to flash units with radio triggers built in.
Though most will also have separate compatible radio triggers as well, built in radio is where its all going right now.
FLASHHAVOC.COM (external link)
apersson850
Gallery: 35 photos
Sep 26, 2013 09:44 as a reply to  @ elv's post |  #8
The coming YN 622 TX is almost a carbon copy of Canon's ST-E3-RT, at least from the outside.
Canon surely did something right there.
Anders
elv
Sep 26, 2013 13:14 |  #9
apersson850 wrote in post #16326766 (external link)
Actually its a photoshop image of a YN-568EX interface which I grafted onto a Canon GPS body :-)
I'd be more impressed if YongNuo actually do their own design though instead of be a Canon imitation.
Lantz
Sep 26, 2013 16:45 as a reply to  @ elv's post |  #10
The King Pro E-TTL Flash Trigger and receivers have ettl and a lcd screen. priced much cheaper than most others that compare.
IMAGE: http://i00.i.aliimg.com/img/pb/687/465/728/728465687_681.jpg
1,409 views & 0 likes for this thread, 7 members have posted to it.
1033 guests, 169 members online
