Thread started 23 Sep 2013 (Monday) 00:10
Focused or ready to focus?
mmahmood
Joined Oct 2012
Sep 23, 2013 00:10 |  #1
Hi,
i shoot with 600D with 18-135mm, my query is when camera beeps and has selected the focusing point in view finder what does it mean
1) either a focusing has been achieved on a specific focusing point or
2) only a focusing point have been selected and camera/lens is yet to focus that point for me?
me kinda confused on this one looking at the images that came out
apersson850
Sep 23, 2013 01:43 |  #2
It means the camera has focused. But it sounds like you are using all focus points, i.e. you let the camera decide where to focus, and then of course the result may not be the one you intended. Select a single point and use that instead, to see if it improves.
Anders
mmahmood
Joined Oct 2012
Sep 23, 2013 02:04 |  #3
apersson850 wrote in post #16317685 (external link)
i have experimented on both settings, here is what is happening with me, lets suppose i had single point selected the moment beep comes i goes with full press of shutter and image came out out of focus, and when beep comes and i wait like a seccond and then take picture it turns out good. and if if i concentrate in view finder it sure does takes that one second or so to get image focused n this is very obvious on single focus point selected,
mmahmood
Joined Oct 2012
Sep 24, 2013 05:03 |  #4
no one !!!!
NewCreation
Gallery: 47 photos
Joined Jan 2013
Sep 24, 2013 05:10 |  #5
You may be getting camera shake and by waiting you are slightly changing your technique.
My name is Brenda ~Saved by grace, walking by faith
http://brendahoffmanph​otography.com (external link)
Facebook (external link)
mmahmood
Joined Oct 2012
Sep 24, 2013 05:18 |  #6
NewCreation wrote in post #16320685 (external link)
i will check on camera shake, but i suppose that scenario i presented is something new, or never reported with 600D+18-135mm combo
mak65
Sep 24, 2013 06:24 |  #7
What shutter speeds are you using? Though it wouldn't explain why one is in focus and the other not. Unless your delay is somehow allowing you to be a bit steadier. Is anything in focus on the picture that doesn't meet your expectations?
gjl711
According to the lazy TF, My flatulence rates
Sep 24, 2013 06:42 |  #8
Post a sample with exif info intact. There are many reasons for a OOF picture some caused by user error and some caused by equipment error. Choose a picture that clearly shows the problem.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
mmahmood
Joined Oct 2012
Sep 24, 2013 07:12 |  #9
i will post pictures with EXIF intact, i guess that will open up grounds to discuss
mmahmood
Joined Oct 2012
Sep 24, 2013 13:18 |  #10
ok here we go with the pictures,i have noticed that the picture in focus has 3 points in focus and other one just 1, here this might be the case but let me dig into the previous pictures and look for case as i have mentioned.
first out of focus picture
IMG_1 (external link) by muhammad mahmood (external link), on Flickr
now the one in focus
IMG_2 (external link) by muhammad mahmood (external link), on Flickr
sapearl
Gallery: 63 photos
Sep 24, 2013 13:28 |  #11
The second image certainly looks sharper than the first, but it also looks like it is more correctly exposed. The first picture looks like it is at least 1-stop overexposed which will give it a softer, less sharp OOF appearance. I am guessing that either your metering might have shifted, resulting in the overexposed shot.
I don't have an EXIF viewer with me right now: what were your shutter speed, aperture and ISO settings?
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
Lbsimon
...never exercised in my life
Gallery: 19 photos
Sep 24, 2013 14:38 |  #12
There is no EXIF. What was the shutter speed?
5D Mark IV | 6D | S110
EF 17-40L | EF 24-105L (two) | EF 70-200L F4 IS | EF 100-400L II | EF 85 1.8 | EF 50 1.8 STM | Canon 1.4x III | Canon 1.4x II
Yongnuo 685 | Nissin Di622 M2 | Nissin Di422
NewCreation
Gallery: 47 photos
Joined Jan 2013
Sep 24, 2013 14:41 |  #13
The exif shows on flickr
1. 1/640 3.5 iso 100
2. 1/1000 3.5 iso 100
icacphotography
Joined Jan 2013
Sep 24, 2013 14:45 |  #14
Looking at what you posted of the EXIF it looks like the main issue is the the fact the lens was wide open and the camera overexposed. so that doesn't necessarily mean it's OOF but given it's overexposed and such it gives that optical illusion. The second one is exposed correctly and appears much sharper. I think it's the fact the metering must have shifted that or it was choosing a different focus point and was able to lock more easily.
Body:50D gripped Magic Lantern'd
Lenses:50mm 1.8,40mm 2.8,28-105 USM II,70-210 F4, 1962 Asahi Pentax Super Takumar 55mm 1.8
Flash: Canon 430 EX
The camera is just a tool - it is not responsible for the picture.
sapearl
Gallery: 63 photos
Sep 24, 2013 14:53 |  #15
NewCreation wrote in post #16321983 (external link)
Thanks for posting that Brenda - much appreciated ;). That shows that there was almost a full stop in exposure difference between the two images. The blown out highlights will reduce apparent sharpness, saturation, contrast and detail in those areas giving the appearance of an OOF image.
Mmahmood, you just need to refine your metering technique better for a more accurate reading and your pictures should greatly improve. Do you recall what metering mode you were using and which areas of the scene you metered?
1,922 views & 0 likes for this thread
Latest registered member is racketproductions
983 guests, 270 members online
